I’m using esp32 with ESPIDF and LVGL 8.3.
I’m experiencing screen drift - which is not LVGL’s fault - explained here. But to combat this I need to store the images in ram, not access them from flash each time. I have already set:
CONFIG_LV_IMG_CACHE_DEF_SIZE=80
CONFIG_LV_MEM_CUSTOM=y
But even just using 2 images in the animimg animation makes the screen drift. I definitely have enough RAM to store these, since I have external RAM on this board. Any ideas?
Hi @robotanical ,
I found enabling the bounce buffer worked for me:
esp_lcd_rgb_panel_config_t panel_config = {
.data_width = 16, // RGB565 in parallel mode, thus 16bit in width
.psram_trans_align = 64,
.num_fbs = LCD_NUM_FB,
.bounce_buffer_size_px = 10 * LCD_H_RES, // I added this line in the panel configuration
.clk_src = LCD_CLK_SRC_DEFAULT,
.disp_gpio_num = PIN_NUM_DISP_EN,
.pclk_gpio_num = PIN_NUM_PCLK,
.vsync_gpio_num = PIN_NUM_VSYNC,
.hsync_gpio_num = PIN_NUM_HSYNC,
.de_gpio_num = PIN_NUM_DE,
.data_gpio_nums = {
PIN_NUM_DATA0,
PIN_NUM_DATA1,
PIN_NUM_DATA2,
PIN_NUM_DATA3,
PIN_NUM_DATA4,
PIN_NUM_DATA5,
PIN_NUM_DATA6,
PIN_NUM_DATA7,
PIN_NUM_DATA8,
PIN_NUM_DATA9,
PIN_NUM_DATA10,
PIN_NUM_DATA11,
PIN_NUM_DATA12,
PIN_NUM_DATA13,
PIN_NUM_DATA14,
PIN_NUM_DATA15,
If this doesn’t work try setting PCLK to a lower value as well…
Kind Regards,
Pete
Thank for the answer @pete-pjb, but I’m afraid that’s not gonna help - I’m already using the double frame buffer - since I wanted more FPS - right now I’m around 12 FPS for reference. And I’m aware that this issue might be fixed by lowering SPIRAM usage but I really want the animations to run smoothly so I want to lower flash usage instead, and load all images to RAM so they can be nicely displayed.
Hi @robotanical ,
In my opinion, to achieve your goals, I would look for a CPU Board with a bit more horsepower as 800 x 480 for the ESP32S3 is really pushing it’s capabilities.
Kind Regards,
Pete
Though the drift doesn’t exist when loading images from C arrays, so it seems to be the only way to get it to work. I really don’t want to have to convert 30+ images and then change all 30+ C files, so I’m trying to find another way.
The point is from what I understand - the images in the animimg should cache - I have set the LV_IMG_CACHE_DEF_SIZE=80, but the definitely don’t - at least not all of them. And in general I definitely have enough RAM, so maybe there’s another memory related setting I don’t see?
