I’m trying to write my own driver. The first draw of the screen works (although with wrong colors), but any touches makes the screen flash black and white randomly and I’ll get partial writes to the display (see attached video). I’m writing code in Platformio using an Arduino framework. I appreciate any help in advance!
Teensy 4.1 with a 320x480 TFT that has a ILI9486 driver. The screen is a clone of lcdwiki 3.5inch_Arduino_Display-UNO (can’t post the link for some reason) and has an 8 bit parallel display. I was able to get the screen to work fine with teensy using the MCUFRIEND_kbv library.
I tried playing with lv_conf.h LV_COLOR_DEPTH and LV_COLOR_16_SWAP. When I try to call my flush_cb function from outside of lvgl I can get a square with a color gradient to display properly. I also tried playing with LV_MEM_SIZE and the size of the frame buffer. I think the problem is with my flush_cb function but I can’t figure it out.
Buffer:
static lv_color_t buf[LV_HOR_RES_MAX * LV_VER_RES_MAX / 5];
flush_cb function:
int32_t x, y;
myGLCD.setColor( *((uint16_t *)color_p) );
myGLCD.drawPixel(x, y);
color_p++;
lv_disp_flush_ready(disp); /* tell lvgl that flushing is done */
Initialization
myGLCD.InitLCD();
myGLCD.fillScr(VGA_WHITE);
lv_log_register_print_cb(my_print); /* register print function for debugging */
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * LV_VER_RES_MAX / 5);
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &disp_buf;
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv); /*Descriptor of a input device driver*/
indev_drv.type = LV_INDEV_TYPE_POINTER; /*Touch pad is a pointer-like device*/
indev_drv.read_cb = my_touchpad_read; /*Set your driver function*/
lv_demo_widgets(); // Start demo
tick.begin(lv_tick_handler, LVGL_TICK_PERIOD * 1000);
Relevant lv_conf.h sections
#define LV_COLOR_DEPTH 16
#define LV_COLOR_16_SWAP 1
# define LV_MEM_SIZE (128 * 1024U)
