I want to click a button so a keyboard and a textarea is opening up on the active screen. then I want to enter a number on the keyboard displayed on the touchscreen. This working so far.
If I click apply on the keyboard the number in the textarea should be saved to a string. But I don’t know how to even save the textarea input into a string variable.
A second problem is i don’t find anything working command to close/delete the textarea. the keyboard closes/deletes nicely. But the textarea is still beeing displayed.
ESP32 Devikit C// Arduino IDE
I want to save the the input from textarea to a string variable.
Also I want the textarea to be closed when the keyboard gets closed.
I tried to read the textarea like mentioned in the LittlevGL documentation but I need some help how to get on.
I tried to send the content of the pointer from textarea to serial monitor but the values are not right no matter what i try ( %d,%u,%c,%s,%n)
And I am kind of new to programming so please don#t be angry if this are stupid questions.
Here is my event for the keyboard event
static void keyboard_event_cb(lv_obj_t * kb, lv_event_t event)
lv_kb_def_event_cb(kb, event);
if(event == LV_EVENT_APPLY))
const char *lv_ta_get_text(const lv_obj_t *ta);
// (this is location where i want to save the
// content from textarea to a string variable later)
printf("%d\n", *lv_ta_get_text); // it tried %d,%u,%c,%n and so on, but the content from
//textarea is not displayed properly in serial monitor
lv_obj_del(kb);
kb = NULL;
if(event == LV_EVENT_CANCEL)
lv_obj_del(kb);
kb = NULL;
printf("keyboard event close \n");
Hey there. Thank you for your time and your answer. You guys are really awesome.
Sadly this does end with a compiler errror ( " ta was not declared in this scope").
Did i miss to add or declare ta somewhere?
This code is used for creating keyboard and textarea :
/*Create styles for the keyboard*/
static lv_style_t rel_style, pr_style;
lv_style_copy(&rel_style, &lv_style_btn_rel);
rel_style.body.radius = 0;
rel_style.body.border.width = 1;
lv_style_copy(&pr_style, &lv_style_btn_pr);
pr_style.body.radius = 0;
pr_style.body.border.width = 1;
/*Create a keyboard and apply the styles*/
lv_obj_t *kb = lv_kb_create(lv_scr_act(), NULL);
lv_obj_set_event_cb(kb, keyboard_event_cb);
lv_kb_set_cursor_manage(kb, true);
lv_kb_set_style(kb, LV_KB_STYLE_BG, &lv_style_transp_tight);
lv_kb_set_style(kb, LV_KB_STYLE_BTN_REL, &rel_style);
lv_kb_set_style(kb, LV_KB_STYLE_BTN_PR, &pr_style);
/*Create a text area. The keyboard will write here*/
lv_obj_t *ta = lv_ta_create(lv_scr_act(), NULL);
lv_obj_align(ta, NULL, LV_ALIGN_IN_TOP_MID, 0, 10);
lv_ta_set_text(ta, "berbelberbelberbel");
lv_obj_set_event_cb(ta, keyboard_event_cb);
/*Assign the text area to the keyboard*/
lv_kb_set_ta(kb, ta);
This is my event code ( with you answer included) did i miss to add ta somewhere?
