This is the first time I have tried to use LVGL as I just learnt about it a couple hours ago. I am trying to get the LVGL arduino example to work on a teensy 4.1 with ILI9341 display. But when I go to compile I get a shitload of undeclared functions and variables.
I am using a teensy 4.1 with arduino ide v1.8.13
For it to work and understand why it isn’t.
/*Using LVGL with Arduino requires some extra steps:
*Be sure to read the docs here: https://docs.lvgl.io/master/get-started/platforms/arduino.html */
#include <lvgl.h>
#include <TFT_eSPI.h>
/*To use the built-in examples and demos of LVGL uncomment the includes below respectively.
*You also need to copy `lvgl/examples` to `lvgl/src/examples`. Similarly for the demos `lvgl/demos` to `lvgl/src/demos`.
*Note that the `lv_examples` library is for LVGL v7 and you shouldn't install it for this version (since LVGL v8)
*as the examples and demos are now part of the main LVGL library. */
//#include <examples/lv_examples.h>
//#include <demos/lv_demos.h>
/*Change to your screen resolution*/
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 240;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print( lv_log_level_t level, const char * buf )
LV_UNUSED(level);
Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
/*Read the touchpad*/
void my_touchpad_read( lv_indev_t * indev_driver, lv_indev_data_t * data )
uint16_t touchX, touchY;
bool touched = tft.getTouch( &touchX, &touchY, 600 );
if( !touched )
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
void setup()
Serial.begin( 115200 ); /* prepare for possible serial debug */
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println( LVGL_Arduino );
Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation( 3 ); /* Landscape orientation, flipped */
/*Set the touchscreen calibration data,
the actual data for your display can be acquired using
the Generic -> Touch_calibrate example from the TFT_eSPI library*/
uint16_t calData[5] = { 275, 3620, 264, 3532, 1 };
tft.setTouch( calData );
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
/*Initialize the display*/
static lv_disp_t disp_drv;
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
static lv_indev_t indev_drv;
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
/* Create simple label */
//lv_obj_t *label = lv_label_create( lv_scr_act() );
//lv_label_set_text( label, LVGL_Arduino.c_str() );
//lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
/* Try an example. See all the examples
* online: https://docs.lvgl.io/master/examples.html
* source codes: https://github.com/lvgl/lvgl/tree/e7f88efa5853128bf871dde335c0ca8da9eb7731/examples */
//lv_example_btn_1();
/*Or try out a demo. Don't forget to enable the demos in lv_conf.h. E.g. LV_USE_DEMOS_WIDGETS*/
lv_demo_widgets();
// lv_demo_benchmark();
// lv_demo_keypad_encoder();
// lv_demo_music();
// lv_demo_printer();
// lv_demo_stress();
void loop()
delay( 5 );
Compilation Error
Arduino: 1.8.13 (Windows 10), TD: 1.58, Board: “Teensy 4.1, Serial, 600 MHz, Faster, US English”
In file included from c:\users\derks_ptmjitt\documents\arduino\libraries\lvgl-master\lvgl.h:79,
from C:\Users\derks_ptmjitt\Documents\Arduino\libraries\lvgl-master\src/lvgl.h:17,
from C:\Users\DERKS_~1\AppData\Local\Temp\arduino_modified_sketch_735231\LVGL_Arduino.ino:4:
c:\users\derks_ptmjitt\documents\arduino\libraries\lvgl-master\src/others/sysmon/lv_sysmon.h:69:2: warning: #warning “lv_sysmon: lv_sysmon is required. Enable it in lv_conf.h (LV_USE_SYSMON 1)” [-Wcpp]
69 | #warning “lv_sysmon: lv_sysmon is required. Enable it in lv_conf.h (LV_USE_SYSMON 1)”
In file included from C:\Users\derks_ptmjitt\Documents\Arduino\libraries\lvgl-master\src/lvgl.h:17,
c:\users\derks_ptmjitt\documents\arduino\libraries\lvgl-master\lvgl.h:121:2: warning: #warning “You are using the development version of LVGL which is not stable at this moment. For production use the release/v8.3 branch. To silence this warning add #define LV_USE_DEV_VERSION to lv_conf.h” [-Wcpp]
121 | #warning “You are using the development version of LVGL which is not stable at this moment. For production use the release/v8.3 branch. To silence this warning add #define LV_USE_DEV_VERSION to lv_conf.h”
In file included from C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/User_Setup_Select.h:30,
from C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/TFT_eSPI.h:68,
from C:\Users\DERKS_~1\AppData\Local\Temp\arduino_modified_sketch_735231\LVGL_Arduino.ino:5:
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/User_Setup.h:205: warning: “TFT_CS” redefined
205 | #define TFT_CS 10 // Chip select control pin
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/User_Setup.h:169: note: this is the location of the previous definition
169 | #define TFT_CS PIN_D8 // Chip select control pin D8
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/User_Setup.h:206: warning: “TFT_DC” redefined
206 | #define TFT_DC 9 // Data Command control pin
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/User_Setup.h:170: note: this is the location of the previous definition
170 | #define TFT_DC PIN_D3 // Data Command control pin
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/User_Setup.h:208: warning: “TFT_RST” redefined
208 | #define TFT_RST -1 // Set TFT_RST to -1 if display RESET is connected to ESP32 board RST
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/User_Setup.h:171: note: this is the location of the previous definition
171 | #define TFT_RST PIN_D4 // Reset pin (could connect to NodeMCU RST, see next line)
In file included from C:\Users\DERKS_~1\AppData\Local\Temp\arduino_modified_sketch_735231\LVGL_Arduino.ino:5:
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/TFT_eSPI.h:89: warning: “PROGMEM” redefined
89 | #define PROGMEM
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/WProgram.h:42,
from C:\Users\DERKS_~1\AppData\Local\Temp\arduino_build_204466\pch\Arduino.h:6:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/avr/pgmspace.h:30: note: this is the location of the previous definition
30 | #define PROGMEM attribute((section(“.progmem”)))
C:\Users\derks_ptmjitt\Documents\Arduino\libraries\TFT_eSPI/TFT_eSPI.h:909:8: warning: #warning >>>>------>> TOUCH_CS pin not defined, TFT_eSPI touch functions will not be available! [-Wcpp]
909 | #warning >>>>------>> TOUCH_CS pin not defined, TFT_eSPI touch functions will not be available!
LVGL_Arduino:19: error: ‘lv_disp_draw_buf_t’ does not name a type
19 | static lv_disp_draw_buf_t draw_buf;
LVGL_Arduino: In function ‘void my_disp_flush(lv_disp_t*, const lv_area_t*, lv_color_t*)’:
LVGL_Arduino:41: error: ‘lv_color_t’ {aka ‘struct lv_color16_t’} has no member named ‘full’
41 | tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
LVGL_Arduino: In function ‘void my_touchpad_read(lv_indev_t*, lv_indev_data_t*)’:
LVGL_Arduino:52: error: ‘class TFT_eSPI’ has no member named ‘getTouch’
52 | bool touched = tft.getTouch( &touchX, &touchY, 600 );
LVGL_Arduino: In function ‘void setup()’:
LVGL_Arduino:97: error: ‘class TFT_eSPI’ has no member named ‘setTouch’
97 | tft.setTouch( calData );
LVGL_Arduino:99: error: ‘draw_buf’ was not declared in this scope
99 | lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
LVGL_Arduino:99: error: ‘lv_disp_draw_buf_init’ was not declared in this scope; did you mean ‘lv_obj_draw_dsc_init’?
LVGL_Arduino:103: error: ‘lv_disp_drv_init’ was not declared in this scope; did you mean ‘lv_fs_drv_init’?
103 | lv_disp_drv_init( &disp_drv );
| lv_fs_drv_init
LVGL_Arduino:108: error: ‘lv_disp_t’ {aka ‘struct _lv_disp_t’} has no member named ‘draw_buf’; did you mean ‘draw_buf_1’?
108 | disp_drv.draw_buf = &draw_buf;
| draw_buf_1
LVGL_Arduino:109: error: ‘lv_disp_drv_register’ was not declared in this scope; did you mean ‘lv_fs_drv_register’?
109 | lv_disp_drv_register( &disp_drv );
| lv_fs_drv_register
LVGL_Arduino:113: error: ‘lv_indev_drv_init’ was not declared in this scope; did you mean ‘lv_fs_drv_init’?
113 | lv_indev_drv_init( &indev_drv );
| lv_fs_drv_init
LVGL_Arduino:116: error: ‘lv_indev_drv_register’ was not declared in this scope; did you mean ‘lv_fs_drv_register’?
116 | lv_indev_drv_register( &indev_drv );
| lv_fs_drv_register
LVGL_Arduino:129: error: ‘lv_demo_widgets’ was not declared in this scope
129 | lv_demo_widgets();
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Adafruit_ILI9341-master: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\Adafruit_ILI9341-master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\OneWire-master: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\OneWire-master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\XPT2046_Touchscreen-master: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\XPT2046_Touchscreen-master
This report would have more information with
“Show verbose output during compilation”
option enabled in File → Preferences.
