Run LVGL ofiicial wedgit demo but only the first picture frame displayed
my LVGL official demo lv_demo_widgets() could display the first frame picture ONLY!
STM32H743IIT6 Keil-MDK compiler-v6.15
I have adapted the LTDC of stm32h743 successfully and verified OK.
I merged the LVGL 9.2.0 into my bare-metal
get the LVGL official demo work well in my board
i have located the problem code but cannot get further.
the problem code is in “static void refr_invalid_areas(void)” >>> “if(disp_refr->inv_p == 0) return;”
/*Copy this file as "lv_port_disp.c" and set this value to "1" to enable content*/
#if 1  /* maple: LVGL 移植:lv_port_disp_templ.c:打开头文件设置1 */
 *      INCLUDES
#include "lv_port_lcd_stm32.h"
#include <stdbool.h>
#include "main.h"
#include "ST7262E43.h"
//#include "gImage_448x300.h"    //ltdc_test
//#include "RGB565_320x240.h"    //ltdc_test
//#include "192x50.h"            //ltdc_test
#include "sdram_fb.h"
 *      DEFINES
#ifndef MY_DISP_HOR_RES
    #warning Please define or replace the macro MY_DISP_HOR_RES with the actual screen width, default value 320 is used for now.
    #define MY_DISP_HOR_RES    320
#ifndef MY_DISP_VER_RES
    #warning Please define or replace the macro MY_DISP_VER_RES with the actual screen height, default value 240 is used for now.
    #define MY_DISP_VER_RES    240
#define BYTE_PER_PIXEL (LV_COLOR_FORMAT_GET_SIZE(LV_COLOR_FORMAT_RGB888))
#define FRAME_BUFFER_DYNAMIC
 *      LTDC 配置
LTDC_HandleTypeDef hltdc;
DMA2D_HandleTypeDef hdma2d;
//-------- ltdc_test ----------
//__IO uint32_t ReloadFlag = 0;
//uint32_t LineEventNumber = 330;
//void ltdc_test(uint8_t test_mode);
 *  STATIC PROTOTYPES
static void MX_LTDC_Init(void);
static void MX_DMA2D_Init(void);
static void disp_init(void);
static void disp_flush(lv_display_t * disp, const lv_area_t * area, uint8_t * px_map);
 *  STATIC VARIABLES
#ifndef FRAME_BUFFER_DYNAMIC
LV_ATTRIBUTE_MEM_ALIGN  // 在SRAM1/2 上分配渲染帧缓存区
__attribute__((section(".RAM_D1")))    static uint8_t buf_2_1[MY_DISP_HOR_RES * MY_DISP_DEPTH * BYTE_PER_PIXEL];
LV_ATTRIBUTE_MEM_ALIGN  // 在AXI-SRAM上分配显示帧缓存区
__attribute__((section(".RAM_D2")))    static uint8_t buf_2_2[MY_DISP_HOR_RES * MY_DISP_DEPTH * BYTE_PER_PIXEL];
#else
static uint8_t* buf_2_1 = NULL;
static uint8_t* buf_2_2 = NULL;
static lv_display_t * disp = NULL;
 *      MACROS
 *   GLOBAL FUNCTIONS
void lv_port_disp_init(void)
    disp_init();  //LTDC and DMA2D Init
    disp = lv_display_create(MY_DISP_HOR_RES, MY_DISP_VER_RES);
    lv_display_set_flush_cb(disp, disp_flush);
    lv_display_set_buffers(disp, buf_2_1, buf_2_2, sizeof(buf_2_1), LV_DISPLAY_RENDER_MODE_PARTIAL);
#else
	//注意:这里是缓冲区深度,而不是屏幕深度,只有全帧缓冲时,缓冲区深度才等于屏幕高度。
    buf_2_1 = (uint8_t*) sdram_alloc_fb(MY_DISP_HOR_RES, MY_DISP_DEPTH, BYTE_PER_PIXEL);
    buf_2_2 = (uint8_t*) sdram_alloc_fb(MY_DISP_HOR_RES, MY_DISP_DEPTH, BYTE_PER_PIXEL);
                            (MY_DISP_HOR_RES * MY_DISP_DEPTH * BYTE_PER_PIXEL),
    // attention: when SDRAM lvgl buffer mode used, must REFRESH the real display buffer address!!!
    HAL_LTDC_SetAddress_NoReload(&hltdc, (uint32_t)buf_2_2, LTDC_LAYER_1);
    //attach optional call backs
    lv_tick_set_cb(HAL_GetTick);
	lv_delay_set_cb(HAL_Delay);
 *   STATIC FUNCTIONS
/*Initialize your display and the required peripherals.*/
	MX_DMA2D_Init();  //must after SDRAM Init
    MX_LTDC_Init();
volatile bool disp_flush_enabled = true;
/* Enable updating the screen (the flushing process) when disp_flush() is called by LVGL
void disp_enable_update(void)
/* Disable updating the screen (the flushing process) when disp_flush() is called by LVGL
void disp_disable_update(void)
    disp_flush_enabled = false;
/*Flush the content of the internal buffer the specific area on the display.
 *`px_map` contains the rendered image as raw pixel map and it should be copied to `area` on the display.
 *You can use DMA or any hardware acceleration to do this operation in the background but
 *'lv_display_flush_ready()' has to be called when it's finished.*/
static void disp_flush(lv_display_t * disp_drv, const lv_area_t * area, uint8_t * px_map)
	// resize the display frame factors
    int32_t width  = area->x2 - area->x1 + 1;
    int32_t height = area->y2 - area->y1 + 1;
    // IMPORTANT: 确保 DMA 获取的像素数据 = CPU 最新渲染数据 → ​图片清晰度提升
    // Attention: MUST get the two lines below configured! or messy display outcome!
   	SCB_CleanInvalidateDCache();  // 强制同步缓存与内存
	SCB_InvalidateICache();       // 确保执行渲染代码最新版
    // 配置DMA2D传输
    HAL_DMA2D_Start_IT(&hdma2d,
                    (uint32_t)px_map,  //DMA2D搬运的起始地址:LVGL需要显示帧的起始地址
                    (uint32_t)buf_2_2, //DMA2D搬运的目的地址:交接给LTDC的固定地址
                    width, height);
    // 设置LTDC显示窗口
    HAL_LTDC_SetWindowPosition_NoReload(&hltdc, area->x1, area->y1, LTDC_LAYER_1);
    HAL_LTDC_SetWindowSize_NoReload(&hltdc, width, height, LTDC_LAYER_1);
    /*IMPORTANT!!!
     *Inform the graphics library that you are ready with the flushing */
    //lv_display_flush_ready(disp_drv);  // 在中断中完成图像显示的剩余操作
	printf("#### LVGL disp_flush\n");
// LTDC重载中断回调函数
void HAL_LTDC_ReloadEventCallback(LTDC_HandleTypeDef *hltdc)
	lv_display_flush_ready(disp);
	printf("---- LTDC: Reload Finished onece more.\n");
// DMA2D传输完成中断回调
void HAL_DMA2D_TransferCpltCallback(DMA2D_HandleTypeDef *hdma2d)
    // 配置垂直消隐期重载准备开始显示
    HAL_LTDC_Reload(&hltdc, LTDC_RELOAD_VERTICAL_BLANKING);
    // 在LTDC重载回调中继续处理
int main(void)
    /* 1. 基础模块配置 */
    MPU_Config();
    CPU_CACHE_Enable();
    HAL_Init();
    SystemClock_Config();
    /* 2. 应用模块配置 */
    MX_GPIO_Init();
    MX_LPUART1_UART_Init();
    SDRAM_Init();
    //-----------LVGL-------------------
    lv_init();  //lvgl core
    lv_port_disp_init();  //lvgl display
    //lv_port_indev_init();  //lvgl touch
    /* lvgl demo */
    lv_demo_widgets();  //LV_USE_DEMO_WIDGETS
    //lv_demo_music();  //LV_USE_DEMO_MUSIC
    //lv_demo_benchmark();
    printf("initialization finished!\n");
    while (1){
        lv_timer_handler();
        HAL_Delay(5);
where is lv_task_handler() ?
where is lv_disp_flush_ready( disp ) ?
I imagine this “lv_tick_set_cb(HAL_GetTick)” is lv_tick_inc( 1 ) ?!
Are you using rtos or bare metal ?
bare metal i use lvgl version 9.2.0 and some apis have been updated
lv_timer_handler(); is the lv_task_handler(); in main while(1);
lv_disp_flush_ready( disp ) is in LTDC ISR
lv_tick_inc( 1 ) is in the ISR of my timebase with TIM6
Are you sure lv_task_handler() is the same thing as lv_timer_handler() ?
I use lvgl version 9.3.0 and I use lv_task_handler().
static inline LV_ATTRIBUTE_TIMER_HANDLER uint32_t lv_task_handler(void)
return lv_timer_handler();
they are the same.
i have solved the problem i post
Cool.
Post the problem and the solution adopted for user queries.
mayebe beceuse of the lack of the running stack and heap , yes just mind the runtime evnvironment for our mcu project resource , the demo functions well
