RP2040 and LVGL
I used generated code from squareline. Tried to compile, but it throws error
{standard input}: Assembler messages:
{standard input}: Error: unaligned opcodes detected in executable segment
exit status 1
Compilation error: exit status 1
What MCU/Processor/Board and compiler are you using? RP2040
I run TFT espi library alone using examples. It works pretty well, so problem must be in LVGL. I also tried using Adafruit_GFX
I can gladly try to help you because I am working on the same subject:
However there are a lot of questions that should be answered to understand the problem:
exit status 1
→ Please share your generated code together with the information about your core application .
RP2040 ok but what is your board? what is your display?
which examples? Share the link. Do you use any IDE ( VsCode, Arduino IDE, Eclipse etc), what is your framework ( PicoSDK, Arduino-Pico (Earlephilhower), Wizio-Pico etc.), do you use PlatformIO ...
How did you try Adafruit GFX?
Share your code; both LvGL code and the application. if application is long you may share a part of it
Yes please !
Even a very small detail makes you application works or not!
I have a similar problem and found this thread when searching. Like the OP, the basic TFT_eSPI library by Bodmer works fine with the examples and my own projects. I’d like to use LVGL for its higher level capabilities.
Environment:
macOS 12.3.1
Pico W (but also fails with standard Pico)
ILI9341 display using SPI
Arduino IDE 1.8.19 (latest)
arduino-pico core 3.1.1 (latest)
LVGL Arduino library 8.3.6 (latest)
GCC 10.3.0 (included with Arduino core)
The error is from the assembler, which runs after the compiler has successfully compiled the C code. The file being compiled is lv_obj.c, which is part of the core LVGL code, so it seems unrelated to any specific example or demo. Google finds a few historical references to this GCC error in other projects but nothing relevant.
Compiler output (redacted):
/Users/xxx/Library/Arduino15/packages/rp2040/tools/pqt-gcc/1.5.0-b-c7bab52/bin/arm-none-eabi-gcc -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0x000a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Raspberry Pi\"" "-DUSB_PRODUCT=\"Pico\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"rpipico\"" -DTARGET_RP2040 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD -iprefix/Users/xxx/Library/Arduino15/packages/rp2040/hardware/rp2040/3.1.0/ @/Users/xxx/Library/Arduino15/packages/rp2040/hardware/rp2040/3.1.0/lib/platform_inc.txt -I/Users/xxx/Library/Arduino15/packages/rp2040/hardware/rp2040/3.1.0/include -std=gnu17 -g -pipe -DF_CPU=133000000L -DARDUINO=10819 -DARDUINO_RASPBERRY_PI_PICO "-DBOARD_NAME=\"RASPBERRY_PI_PICO\"" -DARDUINO_ARCH_RP2040 -Os -I/Users/xxx/Library/Arduino15/packages/rp2040/hardware/rp2040/3.1.0/cores/rp2040 -I/Users/xxx/Library/Arduino15/packages/rp2040/hardware/rp2040/3.1.0/variants/rpipico -I/Users/xxx/Documents/Arduino/libraries/TFT_eSPI -I/Users/xxx/Library/Arduino15/packages/rp2040/hardware/rp2040/3.1.0/libraries/SPI/src -I/Users/xxx/Library/Arduino15/packages/rp2040/hardware/rp2040/3.1.0/libraries/LittleFS/src -I/Users/xxx/Documents/Arduino/libraries/lvgl/src /Users/xxx/Documents/Arduino/libraries/lvgl/src/core/lv_obj.c -o /var/folders/03/s3pv8qk91w78m4_st_nbxl5m0000gn/T/arduino_build_571161/libraries/lvgl/core/lv_obj.c.o
I know what is causing that error. Damn I have to think what it was… Give me a day to poke about and see if I can find where I changed things in order to get it to work.
I am going to do a code compare with what is on the repo and see if I can locate where the issue is.
Thanks.
From my issue at the arduino-pico project, it seems to be a compiler bug. There is a workaround for advanced users: Strange compiler error · Issue #1359 · earlephilhower/arduino-pico · GitHub
I don’t know exactly what code is triggering the bug but I may experiment with some non-functional edits to see if it goes away.
I believe it’s because of unused variables/ There are 2 of them that are declared inside of functions and I honestly don’t remember where they are not am I able to locate the code I changed. While I did not experience your exact problem I encountered compiler errors because of those variables.
To avoid this problem forget about Arduino IDE and use Visual Studio code with Platformio installed on it.
Create new project with “your project name” “raspberry pi Pico board”
Change the content of Platformio.ini
[env:rpipico]
platform = GitHub - maxgerhardt/platform-raspberrypi: Raspberry Pi: development platform for PlatformIO
board = pico
framework = arduino
board_build.core = earlephilhower
step 2: Save your project.
step 3: go to your saved project folder
step 4: copy the content of ui folder given by SLS into platformio / your project/ src
step 5: rename file ui.uno - main.cpp
step 6: copy the content of libraries folder given by SLS into platformio / your project/ lib
I assume you have modified the contents of the “user_setup.h” file according to your hardware.
compile and upload !
(for example)
My “user_setup.h”:
#define ILI9488_DRIVER // WARNING: Do not connect ILI9488 display SDO to MISO if other devices share the SPI bus (TFT SDO does NOT tristate when CS is high)
#define TFT_MISO 0
#define TFT_MOSI 3
#define TFT_SCLK 2
#define TFT_CS 20 // Chip select control pin
#define TFT_DC 22 // Data Command control pin
#define TFT_RST 21
#define TOUCH_CS 14 // Chip select pin (T_CS) of touch screen
// Comment out the #define below to stop the SPIFFS filing system and smooth font code being loaded
// this will save ~20kbytes of FLASH
#define SMOOTH_FONT
#define SPI_FREQUENCY 27000000
// Optional reduced SPI frequency for reading TFT
#define SPI_READ_FREQUENCY 20000000
// The XPT2046 requires a lower SPI clock rate of 2.5MHz so we define that here:
#define SPI_TOUCH_FREQUENCY 2500000
#define USE_HSPI_PORT
I hope this will help you.
this setting worked for me
resim
Resimdeki projenin kaynak kodlarını verme şansınız var mı aynı ekrana sahibim denemeler yapmak istiyorum
Merhaba şu anda çok farklı konular üzerinde çalışıyorum, o çalışmayı geçen sene yapmıştım maalesef bilgilere ulaşmam çok zor.
Diğer yandan, hatırladığım kadarıyla RaspiPico ile LvGL çok da başarılı çalışmadı. Size tavsiyem ESP32S3 deneyin, Elecrow ve WirelessTag markalarının çok güzel displayleri var, wiki lerinde step by step uygulama notları var, ben onlarla daha iyi sonuçlar aldım. Ayrıca illa pico-sdk, vscode diye inat etmemek lazım, Arduino IDE ile çok daha hızlı ve kontrollu başarılı işler yapılabiliyor. Bu arada Pico V2 henüz denemedim sipariş ettim yolda fırsat bulursam onu da deneyeceğim belki Pico V2 ile daha iyi sonuçlar alınabilir.
Bana özelden mail whatsapp yazın haberleşelim.
İyi çalışmalar, başarılar.
Çok teşekkürler hocam, bende şuan pico 2 var yeni geldi, deneme yaparken size gelişmeleri falan yazarım özelden
