Rotating display
Hello!
I would like to know how to rotate display from portrait to landscape.
I use ili9341 display with touch.
The portrait configuration work perfectly but I have no idea where to look to change the orientation.
Thanks!
Jean-Francois
Hi @jfng!
I assume you are using the ili9341 micropython driver.
Please try to change the rot keyword argument of ili9341 constructor. options are: MADCTL_MY, MADCTL_MX, MADCTL_ML, MADCTL_MH. It sets the ILI9341 rotation mode during initialization.
See:
Hello amirgone,
I am not very sure I am using the correct driver…
When I try rot=MADCTL_MY, I got the following error:
MPY: soft reboot
File “main.py”, line 266, in
File “main.py”, line 251, in init_gui
File “main.py”, line 226, in init_gui_esp32
NameError: name ‘MADCTL_MX’ isn’t defined
MicroPython v1.9.4-2071-g87854b53c-dirty on 2019-12-28; ESP32 module with ESP32
Type “help()” for more information.
I build micropython using lv_micropython.
I’m a little bit confuse… How to use the correct driver? I see there is a lv_binding_micropython but don’t know how to use it or integrate it properly…
Thanks!
jfng
Try rot=ili9341.MADCTL_MY
I try:
self.disp = ili9341(rot=ili9341.MADCTL_MY)
And got this:
AttributeError: type object ‘ili9341’ has no attribute ‘MADCTL_MY’
Ok, I try to put the constant directly.
rot=0x80
rot=0x40
rot=0x10
rot=0x04
It seem to do something.
It flip screen correctly but widget only draw on the same axe…
When I try to change width to 320 and height to 240, display draw garbage…
Jean-Francois
Maybe you are using an older version of lv_micropython?
@jfng the following works for me:
import lvgl as lv
import ili9341
disp = ili9341.ili9341(rot=0x20, width=320, height=240)
b = lv.btn(lv.scr_act())
l = lv.label(b)
l.set_text("Hello World!")
Please check if this works for you.
There are a few things to improve in the driver, though:
  • Add a missing constant MV=0x20 (Row / Column Exchange)
  • Move the MADCTL constants into ili9341 class so it would be easier to access them
  • I think the touch driver would need some fix to work on landscape mode. Are you using xpt2046?
I’ve updated lv_micropython_bindings to address these issues.
xpt2046 works well but requires setting transpose=False.
Here is a simple example that creates a draggable button on portrait layout (make sure you use the latest lv_micropython from today):
import lvgl as lv
from ili9341 import ili9341
from xpt2046 import xpt2046
disp = ili9341(rot=ili9341.LANDSCAPE, width=320, height=240)
touch = xpt2046(transpose=False, cal_x0=3780, cal_y0=252, cal_x1=393, cal_y1=3751)
b.set_drag(True)
l = lv.label(b)
The calibration values can be calculated by running tpcal, but it needs to be modified to landscape as well when initializing ili9341 and xp2046 in it)
Hello Amir,
I will update lv_micropython and try your example.
Thank you!
:slight_smile:
Ok, I re-compile lv_micropython with today version and .LANDSCAPE seem to work!
When I try to run tpcal.py, and try new calibration, it’s look like when I drag the point left to right, the point drag up an down and vice-versa.
What value should I change to get the calibration cooresponding to the landscape screen?
HRES = lv.disp_get_hor_res(lv.disp_t.cast(None))
VRES = lv.disp_get_ver_res(lv.disp_t.cast(None))
Register raw resistive touch driver
import rtch
touch = rtch.touch(xp = 32, yp = 33, xm = 25, ym = 26, touch_rail = 27, touch_sense = 33, cal_x0=0, cal_x1 = HRES, cal_y0=0, cal_y1 = VRES)
touch.init()
indev_drv = lv.indev_drv_t()
lv.indev_drv_init(indev_drv)
indev_drv.type = lv.INDEV_TYPE.POINTER;
indev_drv.read_cb = touch.read;
lv.indev_drv_register(indev_drv);
Register xpt touch driver
import xpt2046 as xpt2046
touch = xpt2046.xpt2046(cal_x0=0, cal_x1 = HRES, cal_y0=0, cal_y1 = VRES)
Jean-Francois
Ok! forget the last message!
I just read the comment about xpt2046!
Just add transpose and work perfectly!
Many thanks!
Jean-Francois
Great! You are welcome.
