Placed a switch widget on a screen using Squareline Studio 1.3.4. Was using lvgl 8.3.6 in Arduino IDE 2.2.1. Target is Elecrow Terminal using ESP32-S3 with 3.5" 320x480 TFT.
Since Squareline Studio does not have a provision for rotating the switch 90deg, I added a style to the switch with lv_style_set_transform_angle and rotated it 90deg. Worked fine in 8.3.6. Upgraded to 8.3.11 today and the switch disappeared. The rest of the project works as before. The switch seems to still be there but invisible. Touching the screen where the switch should be invokes the proper response. Checked the HIDDEN flag and also made sure it was still placed on the active screen. No problems there. If I simply remove the transform command, it comes back. I don’t think the API has changed for that command between the versions. Didn’t see any need to post a bunch of code since it works in 8.3.6. Any insights?
I’m seeing the same exact issue with 8.4.1. When using lv_obj_set_style_transform_angle(run_sw, 900, 0);to rotate the switch 90 degrees the switch become invisible.
I would also like to see a solution.
#define LV_COLOR_SCREEN_TRANSP 1
Thanks for the suggestion but it does not work correctly. I can see some pixels lit in the area where it should be but it is not rendered correctly.
