Is there a facility in lvgl to rotate image in the z-direction to mimic 3D rotation ?
3D transforms are not supported in LVGL at the moment.
thanks. I saw the transform and thought that may apply to 3D rotation.
We are implementing the 3D animation widget for LVGL, the idea is to transform the selected image to a set of images according to user’s setting of 3D effect (X,Y, Z rotation, frame rate, etc), and then the animated image widget(https://github.com/lvgl/lvgl/pull/1911) can be used to display. The development is still ongoing.
that is a cost on memory. what i was trying to do is to animate the logo like a rotating coin.
In v9, I’m planning to add this feature (and improve the image transformations in general).
Until that, you can use lv_canvas to make the transformation. For a rotating coin you can do a simple trick: on the first frame copy the whole coin to the canvas, on the next frame skip some columns, on the next skip more columns, etc.
Thanks. I managed to make it work, but using cos is smoother
Is there any example of this in forum or anything like this?
