My design is quite simple at this point. I have a main screen with a single button, and pressing the button launches a new screen also with a single button.
The first screen is created with lv_scr_act as it has no parent. The second screen is created with lv_obj_create with the first screen as a parent.
Screen transition is done with lv_disp_load_scr
v8.3
My expectation is that a new screen should capture all events of my rotary encoder and only children of the new screen are able to be focused by the rotary encoder.
So far I tried the steps described above and now I’m starting to work with what I found from this post:
However, I would expect that input device focus should be applicable only to the active screen. Am I missing something?
Okay… While I wait for more info here I decided to pursue the multi-group route.
Here is what I have:
For my Screen constructor, I’ll first capture the current default group, and, if using an encode/keypad, I’ll create a new group, set my indev to the newly created group, and assign this new group as the default.
For my destructor I undo my changes by deleting the new group, returning the indev to the original group, and reassigning the original group to default.
Does it make sense? Is there a better approach?
Screen::Screen()
: mp_parentGroup{lv_group_get_default()}
lv_indev_t *p_curDrv{lv_indev_get_next(nullptr)};
assert(nullptr != p_curDrv);
if (true == IsRunningKeyEncoder(p_curDrv))
// If using an encoder or keypad create a new group and assign the
// input device to this new group
mp_group = lv_group_create();
lv_indev_set_group(p_curDrv, mp_group);
lv_group_set_default(mp_group);
// If not, the new screen will belong to the parent's group
const lv_group_t *p_group =
static_cast<lv_group_t *>(lv_obj_get_group(GetParentScreen()));
// Current we assume that all screens belong to the 'current' default
// group, so the parent screen must be in the default group. This
// assumption might change depending on requirements, but for now,
// enforce it.
assert(p_group == nullptr);
mp_group = mp_parentGroup;
Screen::~Screen()
// If running encode/keypad return the input device to the parent group and
// delete the group created by this screen
lv_group_del(mp_group);
lv_indev_set_group(p_curDrv, mp_parentGroup);
lv_group_set_default(mp_parentGroup);
