Roller with more than 27 items goes weird
When I add more than 27 items to a roller it starts showing the wrong items as selected. For example it shows 00 then 37 then 03
This seems to happen only when the scroll mode is infinite.
Simulator
8.1
Id like to have a roller that has an item for each minute of the hour (60 items)
Reducing the number of items and incrementing it until it breaks.
Also setting the following made no difference:
#define LV_USE_LARGE_COORD 1
    lv_obj_t * minute = lv_roller_create(cont);
    lv_roller_set_options(minute,
                              "00\n01\n02\n03\n04\n05\n06\n07\n08\n09\n"
                              "10\n11\n12\n13\n14\n15\n16\n17\n18\n19\n"
                              "20\n21\n22\n23\n24\n25\n26\n27\n28\n29\n"
                              "30\n31\n32\n33\n34\n35\n36\n37\n38\n39\n"
                              "40\n41\n42\n43\n44\n45\n46\n47\n48\n49\n"
                              "50\n51\n52\n53\n54\n55\n56\n57\n58\n59"
                              LV_ROLLER_MODE_INFINITE
    lv_obj_align_to(minute, calendar, LV_ALIGN_BOTTOM_RIGHT, 0, 160);
    lv_obj_add_event_cb(minute, cb_calendar_leavingTimeMM, LV_EVENT_ALL, userData);
Thanks!
I don’t what cause this problem but it can be solved by lowering the number of infinite pages by changing the following line in lv_conf.h. ( I tried 3 and it works ).
#if LV_USE_ROLLER
#  define LV_ROLLER_INF_PAGES 3 /*Number of extra "pages" when the roller is infinite*/
Oh, wow. I did try upping it to 10 (and that obviously didnt work). I didnt even think of reducing it…
Does anyone know what this extra “pages” things does?
But yes, thanks, that did fix it for me :slight_smile:
Thanks!
