Looking to improve my search results page that may return 100+ results…
I want to add buttons for <Next 10 results> and <Previous 10 results> to navigate and a click to select the row item.
Questions…
A. Can I disable the rolling on the roller?
B. Can I show no line on the roller as the selected item (so nothing highlighted in blue)
Maybe a list is a better choice for this?
You do lose the infinite scrolling if you switch to a list (just as a heads up). Also, lists consume more memory per item than rollers.
OK so to check i understand what you are suggesting…
Add each search result as a button in my list.
Styled to look less like buttons and more like search results…
Correct?
To populate the list is there a ‘list_set_options’ command similar to when creating the options in a dropdown?
Is there something like
lv_ddlist_get_selected_str
or
lv_roller_get_selected_str
to return the text on the button in the list that has been clicked??
My list shows up to 50 search results and changes every time so I can’t imagine having a separate event handler on each button running lv_list_get_btn_text
would work for me…
From the link I sent you in the last post:
You can use lv_list_get_btn_label(list_btn)
and lv_list_get_btn_img(list_btn)
to get the label and the image of a list button. You can get the text directly with lv_list_get_btn_text(list_btn)
I’m an eejit.
Alright people, remember to use.
lv_list_get_btn_text(obj)
not
lv_list_get_btn_text(listbtn)
Thanks for your patience embeddedt, it is oh so appreciated.
