Right To Left Layout for objects and container
Before posting
Hello
I design a multi-language GUI, for Right To Left language’s need to align right, each object and their container
i remember, i saw a lvgl example for this reason but i don’t remember example name and where i saw, i searched but found nothing,
Anyway
  1. let me know if there is an example
  2. show me the changing code
    thanks in advance
VS Simulator
7.10.0
Right To Left layout changing
// No code;
i have this:
but need these:
I believe enabling LV_USE_BIDI and then calling lv_obj_set_base_dir(obj, LV_BIDI_DIR_RTL) should work.
Thank you.
It’s very usefull.
ALSO i changed font for ddlist and add a string to it:
    lv_obj_add_style(ddlist, LV_OBJ_PART_MAIN,  &style_Language);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_MAIN, &style_Language);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_LIST, &style_Language);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_SELECTED, &style_Language);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_SCROLLBAR, &style_Language);
    lv_obj_add_style(ddlist, _LV_OBJ_PART_REAL_LAST, &style_Language);
    lv_obj_set_style_local_value_str(ddlist, LV_SWITCH_PART_BG, LV_STATE_DEFAULT, "سلام");
    lv_obj_set_style_local_value_str(ddlist, LV_SWITCH_PART_BG, LV_STATE_DEFAULT, "Hello");
"Hello");
BUT it shoe’s only English character, and for “سلام” show’s just nothing, currently i use an label,
is there any tip/trick for this my little problem?
Now
i have this:
    lv_cont_set_layout(cont1, LV_LAYOUT_COLUMN_LEFT);
    lv_obj_align(label_type, ui.ddlist_key_type, LV_ALIGN_OUT_LEFT_MID, -5, 0);
Result is:
111
    lv_obj_align(label_type, ui.ddlist_key_type, LV_ALIGN_OUT_RIGHT_MID, 5, 0); // Changed
Result is:
222
    lv_cont_set_layout(cont1, LV_LAYOUT_COLUMN_RIGHT); // Changed
Result is:
333
Now question is:
every time i create an object, i should check the language setting and set:
LV_BIDI_DIR_RTL / LV_BIDI_DIR_LTR
LV_LAYOUT_COLUMN_RIGHT / LV_LAYOUT_COLUMN_LEFT
LV_ALIGN_OUT_RIGHT_MID / LV_ALIGN_OUT_LEFT_MID
for every single object or there is a better WaY??
Did you set value_font on style_Language as well or just text_font?
Note: please check what parts you are applying styles to. Right now you have base object and switch parts in use, even though you’re applying these styles to a dropdown.
I am not sure as I don’t really use the RTL feature in my projects. However, I think @amirgon or @kisvegabor would know.
You set the root object base dir, and the direction would be inherited by each child object you add to it, unless explicitly specified otherwise.
Thank’s a lot,
but i cant find any documentation about lv_obj_set_style_local_value_str
Thank you.
In the spot where you are setting the custom font, you must be setting the text_font property. What I am suggesting is to change value_font in that location as well (just copy the line and change text_font to value_font).
:ok_hand:
Thanks
 static lv_style_t style;
    lv_style_init(&style);
    lv_style_set_text_font(&style, LV_STATE_DEFAULT, &lv_font_dejavu_16_persian_hebrew);//change font
    lv_style_set_value_font(&style, LV_STATE_DEFAULT, &lv_font_dejavu_16_persian_hebrew);//change font
    lv_obj_t* ddlist = lv_dropdown_create(ui.tab1, NULL);
    lv_obj_add_style(ddlist, LV_OBJ_PART_MAIN, &style);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_MAIN, &style);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_LIST, &style);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_SELECTED, &style);
    lv_obj_add_style(ddlist, LV_DROPDOWN_PART_SCROLLBAR, &style);
    lv_dropdown_set_options(ddlist, "   آبی   \n   قرمز  \n   سبز   ");
    lv_obj_set_width(ddlist, 150);
     lv_obj_set_pos(ddlist, 80, 20 + 35 + 70);
    lv_dropdown_set_selected(ddlist, 0);
    lv_dropdown_set_show_selected(ddlist, false);
    lv_dropdown_set_text(ddlist, "سلام");
result is a exploded: 12
Is there any problem in my code?
But i did this:
  lv_dropdown_set_text(ddlist, " ");//a blank
    lv_obj_set_style_local_value_align(ddlist, LV_SWITCH_PART_BG, LV_STATE_DEFAULT, LV_ALIGN_IN_RIGHT_MID);
    lv_obj_set_style_local_value_ofs_x(ddlist, LV_SWITCH_PART_BG, LV_STATE_DEFAULT, -5);
Result is OK:122
in first place how i change my code to display correct string by using:
Looks like a bug in LVGL.
Worth opening an issue on GitHub.
Thanks a lot.
I still have problem with alignment
   lv_obj_set_base_dir(ui.tab2, LV_BIDI_DIR_RTL);
    lv_obj_t* contA = lv_cont_create(ui.tab2, NULL);
    lv_obj_t* contB = lv_cont_create(ui.tab2, NULL);
    lv_obj_t* contC = lv_cont_create(ui.tab2, NULL);
    lv_obj_set_size(contA, 150, 50);
    lv_obj_set_size(contB, 150, 150);
    lv_obj_set_size(contC, 150, 250);
    lv_obj_align(contA, NULL, LV_ALIGN_IN_TOP_LEFT, 10, 120);
    lv_obj_align(contB, contA, LV_ALIGN_OUT_RIGHT_TOP, 0, 0);
    lv_obj_align(contC, contB, LV_ALIGN_OUT_RIGHT_MID, 0, 0);
these 3 container’s aligned for LTR languages,
after changing to RTL i want to auto alignment for these container to change those position
is there any variable to say to LVGL for auto change its alignment?
or i should do it manually?
Please let me know if there is any problem with my question.
@embeddedt
I wasn’t sure, so I didn’t answer. :slightly_smiling_face:
I think you have to do it manually, but again I don’t use RTL so I can’t say for sure.
The automatic changes in layout and alignments are not supported now. I think it’d be misleading to align to the left when you type LV_ALIGN_IN_RIGHT_TOP.
FYI, in v8 the layouts operate with the START and END keywords, and their meaning is changed according to the base dir.
:ok_hand:
Thank you.
:ok_hand:
Thank you.
good job.
