Retrieving data from a text area
How do I get data from a text area?
STM32F401
7
Set time from text area
From a standard example
the txt variable contains the initial value and is not updated and the interrupt is triggered.
static void ta_event_cb(lv_obj_t * ta, lv_event_t event)
if(event == LV_EVENT_VALUE_CHANGED) {
const char * txt = lv_textarea_get_text(ta);
if(txt[3] == ‘:’) {
lv_textarea_del_char(ta);
else if(txt[0] >= ‘0’ && txt[0] <= ‘9’ &&
txt[1] >= ‘0’ && txt[1] <= ‘9’ &&
txt[2] != ‘:’)
lv_textarea_set_cursor_pos(ta, 2);
lv_textarea_add_char(ta, ‘:’);
How can I get the time value printed in the text area like this
RTC_DateTime.RTC_Hours = 0;
RTC_DateTime.RTC_Minutes = 0;
RTC_DateTime.RTC_Seconds = 0;
for further change of RTS registers. Thanks.
Use lv_textarea_get_text(ta) to get the text from lv_textarea widget
