What are the LVGL restrictions when targeting a device that uses High Color (16 bit) like the Raspberry Pi?
Trying to draw a rectangle (via Canvas) however some issues have occurred:
- Shadows aren’t drawn
- Borders aren’t drawn
- Setting a background gradient color causes the rectangle to be invisible
- A Segmentation Fault occurs when setting background opacity, or background gradient direction
What is the formula for calculating the canvas buffer size when High Color is used? I am following the Canvas 1 example however it isn’t designed with High Color in mind (what changes need to be made?).
Very strange that a Rectangle Descriptor requires a color format, yet a LVGL object doesn’t require a color format. A gradient and shadow is shown on a LVGL object, however no gradient and shadow is shown on a rectangle (via a Rectangle Descriptor). The following fields can be successfully set on an LVGL object:
- bg_opa
- bg_grad_dir
- bg_grad_color
- shadow_width
- shadow_ofs_x
- shadow_ofs_y
Below is the LVGL object version which shows the gradient, border, and shadow:
LvglObject.create(Screen.activeScreen).apply {
setRadiusStyle(5)
setBackgroundOpacityStyle(LV_OPA_COVER.toUByte())
setBackgroundColorStyle(lightenPaletteColor(LV_PALETTE_GREY, 1u))
setBackgroundGradientColorStyle(mainPaletteColor(LV_PALETTE_BLUE))
setBackgroundGradientDirectionStyle(LV_GRAD_DIR_VER.toUByte())
setBackgroundMainStopStyle(128)
setBackgroundGradientStopStyle(192)
setShadowWidthStyle(5)
setShadowXOffsetStyle(5)
setShadowYOffsetStyle(5)
setBorderWidthStyle(2)
setBorderOpacityStyle(LV_OPA_90.toUByte())
setBorderColorStyle(mainPaletteColor(LV_PALETTE_GREEN))
center()
Below is the Rectangle Descriptor version, which doesn’t show the gradient, border, and shadow:
rectangleDescriptor {
radius = 10
// Causes seg fault.
// backgroundOpacity = LV_OPA_COVER.toUByte()
// backgroundGradientDirection = LV_GRAD_DIR_HOR.toUByte()
backgroundColor = mainPaletteColor(LV_PALETTE_RED)
// Causes the rectangle to be invisible.
// backgroundGradientColor = mainPaletteColor(LV_PALETTE_BLUE)
borderWidth = 2
borderOpacity = LV_OPA_90.toUByte()
borderColor = lv_color_white().toColor()
shadowWidth = 5
shadowYOffset = 5
shadowXOffset = 5
It appears as though there are some bugs with Rectangle Descriptor and/or Canvas in the LVGL library.
By “High color” you mean RGB565, right? If so, it’s the most common format for embedded so it’s very well supported.
I can’t clearly see how your code is mapped to C and what happens in the background. For example in LVGL backgroundOpacity is called bg_opa.
Could you test in a simulator in C and send a code snippet that we can use the reproduce the issue?
There is a Git branch I have created that reproduces the issues. Just about all relevant code can be found in the drawRectangle function. Despite the fact that it isn’t C code the Kotlin code is close enough to C that it can be easily converted. Some relevant code is positioned towards the top of the source file:
private const val CANVAS_WIDTH = 200.toShort()
private const val CANVAS_HEIGHT = 150.toShort()
private val arena = Arena()
private val canvasBuf = arena.allocArray<lv_color_t>(trueColorBufferSize(CANVAS_WIDTH, CANVAS_HEIGHT).toInt())
We found a bug in a recent gradient feature. It should work well now.
Which LVGL version contains the fix?
