Resize the simulator screen in codeblock
I am trying to rescale the size of simulator screen in Code blocks from 480x320 px to 320x240 px
I am using latest Code block windows simulator
I have already fully designed a project using 480x320 px screen size on the Codeblocks simulator. However, my client wanted it to be in 320x240 px screen size.
I’ve tried to change the LV_HOR_RES and LV_VER_RES in lv_conf.h but to no luck. I’ve also tried to change the resolution in lv_drv_conf.h but still displayed the default size. I’ve cleaned the workspace and rebuild the project, but it still shows 480x320 screen size.
void lv_demo_try(void)
static lv_style_t style;
lv_style_init(&style);
/*Set a background color and a radius*/
lv_style_set_bg_color(&style, LV_STATE_DEFAULT, LV_OFFICIAL_COLOR);
lv_style_set_border_width(&style, LV_STATE_DEFAULT, 0);
lv_obj_t * win = lv_win_create(lv_scr_act(), NULL);
lv_obj_set_size(win, 480, 500);
lv_obj_align(win, NULL, LV_ALIGN_CENTER, 0,-50);
lv_obj_add_style(win, LV_STATE_DEFAULT, &style);
lv_obj_t * img = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(img, &official_logo);
lv_obj_align(img, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_t * label;
lv_obj_t * obj1 = lv_obj_create(lv_disp_get_scr_act(NULL), NULL);
lv_obj_align(obj1, NULL, LV_ALIGN_IN_BOTTOM_MID, 10 ,0);
lv_obj_add_style(obj1, LV_STATE_DEFAULT, &style);
label = lv_label_create(obj1, NULL);
lv_label_set_recolor(label, true);
lv_label_set_text(label, "#ffffff CLICK HERE#");
lv_obj_set_event_cb(obj1, login_page);
In the lv_drv_conf.h line 118.
in visual studio, i just change
/* Maximal horizontal and vertical resolution to support by the library.*/
#define LV_HOR_RES_MAX (440)
#define LV_VER_RES_MAX (440)
in lv_conf.h and rebuild.
may need clean before build?
The codeblocks project that I am using has a hard coded value for Windows while most of the other display drivers use the 2 defines you posted. I think I saw 1 other display driver that uses hard coded values. Don’t know if that is left over from an old version or there is some reason for it. I think there was some problem with the windows simulator because embeddet had said he used a different graphics lib.
Please confirm that the following lines have been changed to your desired resolution:
After that, a clean and rebuild should pick up on the new settings.
I designed the Windows driver to use Windows APIs directly to avoid needing another dependency like SDL. The two defines approach is cloned from the standard SDL driver. In practice, I could have set it up to use LV_HOR_RES_MAX and LV_VER_RES_MAX, but for consistency I wanted to keep it the same as other drivers.
