Thank you for the suggestion.
I add some additional code to lv_canvas.c
for a canvas can support drawing for LV_IMG_CF_TRUE_COLOR_ALPHA canvas-buffer.
such as lv_canvas_draw_rect(...) , lv_canvas_draw_text(...),
lv_canvas_draw_line(...) , lv_canvas_draw_polygon(...).
Do you mind to give any suggestion about the following code?
lv_canvas_draw_rect(...) can use for LV_IMG_CF_TRUE_COLOR_ALPHA too
(in lv_canvas.c with additional code)
void lv_canvas_draw_rect(lv_obj_t * canvas, lv_coord_t x, lv_coord_t y, lv_coord_t w, lv_coord_t h,
const lv_style_t * style)
lv_img_dsc_t * dsc = lv_canvas_get_img(canvas);
/* Create a dummy display to fool the lv_draw function.
* It will think it draws to real screen. */
lv_area_t mask;
mask.x1 = 0;
mask.x2 = dsc->header.w - 1;
mask.y1 = 0;
mask.y2 = dsc->header.h - 1;
lv_area_t coords;
coords.x1 = x;
coords.y1 = y;
coords.x2 = x + w - 1;
coords.y2 = y + h - 1;
lv_disp_t disp;
memset(&disp, 0, sizeof(lv_disp_t));
lv_disp_buf_t disp_buf;
lv_disp_buf_init(&disp_buf, (void *)dsc->data, NULL, dsc->header.w * dsc->header.h);
lv_area_copy(&disp_buf.area, &mask);
lv_disp_drv_init(&disp.driver);
disp.driver.buffer = &disp_buf;
disp.driver.hor_res = dsc->header.w;
disp.driver.ver_res = dsc->header.h;
// link to manual set_px_cb if canvas's buffer is LV_IMG_CF_TRUE_COLOR_ALPHA type
if(dsc->header.cf == LV_IMG_CF_TRUE_COLOR_ALPHA)
disp.driver.set_px_cb = lv_canvas_truecolor_alpha_set_px_cb;
#if LV_ANTIALIAS
/*Disable anti-aliasing if drawing with transparent color to chroma keyed canvas*/
lv_color_t ctransp = LV_COLOR_TRANSP;
if(dsc->header.cf == LV_IMG_CF_TRUE_COLOR_CHROMA_KEYED &&
style->body.main_color.full == ctransp.full &&
style->body.grad_color.full == ctransp.full)
disp.driver.antialiasing = 0;
lv_disp_t * refr_ori = lv_refr_get_disp_refreshing();
lv_refr_set_disp_refreshing(&disp);
lv_draw_rect(&coords, &mask, style, LV_OPA_COVER);
lv_refr_set_disp_refreshing(refr_ori);
and add manual lv_canvas_truecolor_alpha_set_px_cb(..) like this.
static void lv_canvas_truecolor_alpha_set_px_cb(struct _disp_drv_t * disp_drv, uint8_t * buf, lv_coord_t buf_w, lv_coord_t x, lv_coord_t y,
lv_color_t color, lv_opa_t opa)
// at now support for color-depth 16 bit
#if LV_COLOR_DEPTH == 16
uint16_t* buf_color = (uint16_t*) &buf[ (x + y*buf_w)*3];
if(opa == LV_OPA_COVER) {
*buf_color = color.full;
}else{
lv_color_t bg_tmp; bg_tmp.full = *buf_color;
lv_color_t opa_tmp = lv_color_mix(color, bg_tmp, opa);
*buf_color = opa_tmp.full;
