Replace the knob of lv_slider with an image
i am using lv_slider in my project. I want to replace knob whit a image or create an image on knob.
but I don’t know what to do.(sorry, my english is not good, If the description is not clear, please let me know )
v7.0
I tried to change the knob style, but the results were not ideal
I think you can do this by setting the pattern_image property in a style and then applying that to LV_SLIDER_PART_KNOB.
Hi,embeddedt. I have trid it,but there are some errors. Below is my code,
    lv_style_t style;
    lv_style_init(&style);
	lv_style_set_pattern_image(&style, LV_STATE_DEFAULT, LV_SYMBOL_OK);
	lv_obj_t *slider = lv_slider_create(lv_scr_act(), NULL);
	lv_obj_add_style(slider, LV_SLIDER_PART_KNOB, &style);
	lv_obj_set_size(slider, 280, 100);
	lv_obj_align(slider, NULL, LV_ALIGN_CENTER, 0, 0);
	lv_slider_set_range(slider, 0, 100);
Can you use image resources for this,like this
lv_style_set_pattern_image(&style, LV_STATE_DEFAULT, &img_cogwheel_argb);
Yes; I’m pretty sure that images will work as well as symbols.
Your code works well for me in the simulator.
Thanks,I will check what went errors.
I am using version 7.0.1, I also updated to 7.1.0 to try.Unfortunately,none of them work properly.
:sob:
lv_style_t style; should be static lv_style_t style;
See https://docs.lvgl.io/latest/en/html/overview/style.html#initialize-styles-and-set-get-properties
I have done it ,thanks
Good afternoon, can I use another object, such as canvas, instead of an image?
Unfortunately, you have to use an image as the slider handle is not a real object.
Thanks for the answer
Is this possible to add image on slider knob with lvgl v8.2?
