I am using a monochrome display, bitmap pixel data send by lvgl is in horizontal direction. My display renders bitmap in vertical direction.
Is there already a way to render display column first then proceed for next column.
To handle monochrome displays with vertical bit alignment you need to to
- be sure that LVGL always redraws a multiple of 8 rows.
- In v8 see the
rounder_cb - In v9 you can use catch the
LV_EVENT_INVALIDATE_AREAsent to the display and modify the area to be invalidated. (uselv_display_add_event)
- In v8 see the
- In the
flush_cbconvert the colors if needed - Send the rendered image to the display.
