A rectangular bar appears near the bottom of the screen when label text falls outside of the visible screen area. The length of the bar decreases as more of the text is outside of the screen boundaries.
We are using lvgl-8.0.2
MAX32672 (Cortex-M4F) EV Kit (not currently public)
Eliminate rendering artifact
Enabled all internal consistency checks, nothing noted.
and ```
tags:
#define LV_COLOR_DEPTH 16
#define LV_FONT_UNSCII_8 1
#define LV_FONT_DEFAULT &lv_font_unscii_8
#define LV_TXT_ENC LV_TXT_ENC_ASCII
/* Generate a text label to bounce around the screen */
label1 = lv_label_create(lv_scr_act());
lv_label_set_text(label1, "Test\nLonger Line");
lv_obj_set_style_text_align(label1, LV_TEXT_ALIGN_CENTER, 0);
/* Later on -- let x := {-20, 30} and y := {-50, 25} */
lv_obj_set_pos(label1, x, y);
