Best possible render time with the setup below.
MCU - STM32U585
SPI Display - 128x400 LCD
UI - Custom images and animations on it, like a slider and a progress bar, are prepared.
Custom slider screen render time is around 40ms. On concurrent use of the same, it goes around 70ms. Whereas the actual slider widget render time is around 20ms.
How to achieve the best render time?
What are the possible optimization techniques?
Any reference available for render time calculation and comparison?
However, to measure the render time with default LVGL functionality, when we enable the macros, “#define** LV_USE_SYSMON 1” & “#define** LV_USE_PERF_MONITOR 1”, lv_init() fails.
We are trying to measure render time manually with the GPIO as follows:
HAL_GPIO_WritePin(RENDER_TIME_GPIO_Port, RENDER_TIME_Pin, GPIO_PIN_SET);
lv_timer_handler();
HAL_GPIO_WritePin(RENDER_TIME_GPIO_Port, RENDER_TIME_Pin, GPIO_PIN_RESET);
Please let us know if you have any suggestions.
Please find attached lv_conf.h file for your reference.
Does the display you are using have built in memory? If you don’t know then tell me what the model number is for the display IC and I will tell you if it does or doesn’t.
It sounds like you are using a single buffer that is width * height * bytes_per_pixel in size. If the display you are using has built in memory (GRAM) then you can actually set that size so it is a lot smaller. like 1/10th the size. make 2 buffers that size and allocate them in DMA memory and set up proper double buffering using DMA with setting the render type to PARTIAL in lvgl. Don’t forget you will need to register a callback with the SPI driver for your MCU to get signaled that a transmission has completed. in that callback is when you call the flush ready function in lvgl.
Enabling double buffering using partial buffers is going to be a lot faster. 40mhz SPI is slow to begin with and that is going to be your bottleneck especially with a display that is 128 * 400 in size. That’s a lot of data it is going to be sending at a pretty slow speed.
@kdschlosser ,
We have tried the partial frame buffer, but when the frame was uploaded to display over SPI, only some part of the display got updated, and not the full display. So, this approach does not work for us.
While using the double frame buffer, render time is already coming high. So, it’s not helping much.
Could you help to confirm whether the way we are measuring render time is correct or not? Is there any other way to measure the render time?
When using the default LVGL macro “LV_USE_PERF_MONITOR” to measure it, the LVGL init crashes. Do you have any suggestion that how we can enable it so that the LVGL itself print the render time?
OK that is one of those funky display driver IC’s that does have GRAM but it still requires transmitting a full frame buffer. I really do dislike those kinds of display IC’s because they are going to be extremely slow because of having to render full frame buffers.
The only way to improve the performance is if you connect the display to a dual core MCU and you are going to need to have enough DMA able memory to hold 2 full frame buffers plus n additional 2 partial frame buffers that don’t have to be in DMA memory. The code that you need to write needs to be able to use both cores of the MCU. one core would be running LVGL and writing to one of the partial frame buffers while the other core is copying the data from the second partial frame buffer and writing it to the full frame buffer that is not transmitting and the other full frame buffer is transmitting using DMA memory. you need to use an RTOS like FreeRTOS using multiple lock/mutex to control the flow of who does what and when so you don’t end up reading data from a buffer that is being written to. This is the ONLY way you will get any kind of decent performance with using that display. IDK why they even provide an SPI connection because it should not be used. That IC does provide a MIPI DSI connection and also an I8080 connection and those would be a hell of a lot faster due to the DSI being able to transmit at 1 gHz or the I8080 being able to transmit over 16 lanes at 80mHz per lane. but the SPI having a single lane at 80mHz at best is going to take a horribly long amount of time to send upwards of 691,200 bytes of data. You are looking at 69.12 milliseconds to send a single frame and that is an at best theoretical speed. that’s for a 480x480x24 resolution and color depth. That is incredibly slow.
