I’m using STM32H7 at 240M CPU rate in OS environment, only UI thread and ms tick are run, the rest thread are suspend.
Lvgl is set in one buffer(320 * 30) mode with DMA SPI(design at 24Hz FPS, 30M spi clock) for TFT 320 * 280.
LV_FAST_RAM has assigned to deticated ram block, the same with all key function code.
Monitor call back shows the px refresh:
I try to find out what makes render time too long:
1)use lv_get_tick to confirm spi_dma function -->> every flush cb use 1ms or less. So I can get an conclusion that dma spi is right to use.
2)use oscilloscope and gpio to view what takes the most of the rendering time
–>>from gpio time I find out ‘lv_refr_obj_and_children’ takes the most, ‘lv_refr_obj’ execute many times use 1ms or less. This is accord with the screen render process.
3)use single step debug to confirm ‘LV_EVENT_DRAW_MAIN(POST,PART)_BEGIN’, ‘LV_EVENT_DRAW_MAIN(POST,PART)’, ‘LV_EVENT_DRAW_MAIN(POST,PART)_END’ are synchronous in one lv_task_handler
–>> single step debug seems can confirm this
4)try to calc one px update time
–>>for 7887 px refreshed in 137ms, one px is 17.4us. This means 1 px use 17.4us * 240M = 4176 cpu instruction.
for 48394 px refreshed in 418ms, one px is 8.64us. This means 1 px use 8.64us * 240M = 2073 cpu instruction.
for 48475 px refreshed in 268ms, one px is 5.53us. This means 1 px use 8.64us * 240M = 1326 cpu instruction.
5)enable DMA2D function to faster blend process -->> seems little improve fro render time. I think basic draw process(rect, angle and so on…) and masking process take the most.
This render time cause my TFT refresh too slow, after use a lot of time to analyse it, little optimize I can make. Do you have some suggestion for me?
