Remove space between list elements on LVGL 7.7.2
codeblocks simulator, atmel studio with GCC
LVGL 7.7.2
Remove the space between list elements
I tried using code snippets from
https://forum.lvgl.io/t/how-to-remove-space-between-buttons-in-list/865
but it does not compile with LVGL 7.7.2. I can’t use lv_list_set_style().
I tried lv_obj_set_style_local_pad_all() and lv_obj_set_style_local_margin_all() on LV_LIST_PART_SCROLLABLE and LV_LIST_PART_BG. They don’t affect the spacing between the button list elements.
As long as I can somehow get which element of the list is selected, I don’t mind if I don’t use buttons.
Also, is it possible to continuously show the scrollbar on the right?
void lv_ex_list_1_mine(void)
/*Create a list*/
lv_obj_t * list1 = lv_list_create(lv_scr_act(), NULL);
lv_obj_set_size(list1, 160, 200);
lv_obj_align(list1, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_style_local_text_font(list1, LV_LIST_PART_BG, LV_STATE_DEFAULT, &lv_font_montserrat_12);
/*does not change spacing between elements. It changes the spacing between the whole list and the border*/
lv_obj_set_style_local_pad_all(list1, LV_LIST_PART_SCROLLABLE, LV_STATE_DEFAULT, 0);
/*don't see the effect*/
lv_obj_set_style_local_margin_all( list1, LV_LIST_PART_SCROLLABLE, LV_STATE_DEFAULT, 0);
lv_obj_set_style_local_pad_all( list1, LV_LIST_PART_BG, LV_STATE_DEFAULT,0);
static lv_style_t styleSCRL;
lv_style_init(&styleSCRL);
/*in LVGL 7.7.2, lv_style_t has no member body*/
/*styleSCRL.body.padding.top = 0;*/
/*styleSCRL.body.padding.bottom = 0;*/
/* styleSCRL.body.padding.left = 0;*/
/* styleSCRL.body.padding.right = 0;*/
/* lv_list_set_style(list1, LV_LIST_STYLE_SCRL, &styleSCRL);*/
/*lv_list_set_style() not in LVLG 7.7.2 */
/*LV_LIST_STYLE_SCRL not in LVLG 7.7.2*/
/*Add buttons to the list*/
lv_obj_t * list_btn;
list_btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "A");
lv_obj_set_event_cb(list_btn, event_handler_mine);
list_btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "B");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "C");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "D");
