ESP32-C3
v9, esp_lvgl_port 2.3.3
I want to have nested flex containers, one vertical and one horizontal, without padding.
I tried to set all padding & margin values to zero but it doesn’t seem to work. As soon as there are two nested flex containers the whole thing gets shifted by a few pixels to the right. When I print the coordinates of the last image, it is at x=105, but when I manually place the same image at the same coordinates, it is ~3px to the left (which would be correct). (int)lv_obj_get_x(_icons[5]) is what i’m using to get the X coordinate. You can see that in the image icon at the very end.
Here is my code, sorry it’s not 100% self-contained but hopefully enough? I hope the problem is obvious without needing to execute this, otherwise I’ll create a smaller example. The code is already slightly simplified.
LV_IMAGE_DECLARE(dice1);
void create() {
lv_obj_t *_root = nullptr;
std::vector<lv_obj_t*> _icons;
_root = lv_obj_create(nullptr);
// flex doesn't make a difference
//lv_obj_set_layout(_root, LV_LAYOUT_FLEX);
//lv_obj_set_flex_flow(_root, LV_FLEX_FLOW_COLUMN);
//lv_obj_set_flex_align(_root, lv_flex_align_t::LV_FLEX_ALIGN_SPACE_BETWEEN, lv_flex_align_t::LV_FLEX_ALIGN_CENTER, lv_flex_align_t::LV_FLEX_ALIGN_CENTER);
lv_obj_set_width(_root, lv_pct(100));
lv_obj_set_height(_root, lv_pct(100));
lv_obj_set_style_pad_column(_root, 0, 0);
lv_obj_set_style_pad_row(_root, 0, 0);
lv_obj_set_style_pad_all(_root, 0, 0);
lv_obj_set_style_margin_all(_root, 0, 0);
lv_obj_set_style_pad_gap(_root, 0, 0);
auto diceRow = lv_obj_create(_root);
lv_obj_set_layout(diceRow, LV_LAYOUT_FLEX);
lv_obj_set_flex_flow(diceRow, LV_FLEX_FLOW_ROW);
lv_obj_set_width(diceRow, lv_pct(100));
lv_obj_set_height(diceRow, LV_SIZE_CONTENT);
lv_obj_set_style_pad_column(diceRow, 0, 0);
lv_obj_set_style_pad_row(diceRow, 0, 0);
lv_obj_set_style_pad_all(diceRow, 0, 0);
lv_obj_set_style_margin_all(diceRow, 0, 0);
lv_obj_set_style_pad_gap(diceRow, 0, 0);
for(int i = 0; i < 6; ++i) {
lv_obj_t * icon = lv_image_create(diceRow);
lv_image_set_src(icon, &dice1);
_icons.push_back(icon);
lv_obj_t * icon = lv_image_create(_root);
lv_obj_set_pos(icon, 105, 25);
This looks like this:
But this code:
auto diceRow = lv_obj_create(nullptr);
_root = diceRow;
Looks like this:
This is correct as the display is 128pixels wide & each image is 21x21px, meaning 6 take up 126 pixels.
How do I make this works with nested containers? Why does the upper container introduce some padding & why do the coordinates that i get using get_x differ from the ones where the images are actually drawn?
