I am creating a custom menu which will ultimately contain controls within each item (so they are a bit more than just a list of labels). For this I am using a container with the alignment set to LV_LAYOUT_COL_M and then I add my custom obj items. However there is spacing/padding between each item which I do not want.
I’m believe this is something to do with the style but nothing I have tried as worked.
Visual Studio simulation. LittleVgl6.0
Aligned objects without spacing between them (see screenshot below).
See code below. I have tried changing the body.padding to top and bottom but made no difference.
static lv_style_t titlestyle;
static lv_style_t helpstyle;
static void CreateNewMenu()
// Base container ************************************
lv_obj_t* base = lv_list_create(lv_scr_act(), NULL);
lv_obj_set_size(base, 800, 400);
lv_cont_set_layout(base, LV_LAYOUT_COL_M);
// Setup styles ************************************
lv_style_copy(&titlestyle, &lv_style_plain);
lv_style_copy(&helpstyle, &lv_style_plain);
titlestyle.text.color = LV_COLOR_WHITE;
titlestyle.text.font = &lv_font_roboto_28;
titlestyle.body.main_color = lv_color_hex(0x134b8e);
titlestyle.body.grad_color = lv_color_hex(0x134b8e);
//titlestyle.body.padding.bottom = 0;
//titlestyle.body.padding.top = 0;
helpstyle.text.color = LV_COLOR_CYAN;
helpstyle.text.font = &lv_font_roboto_12;
// Creating menu items ************************************
CreateMenuItem(base, "Item1");
CreateMenuItem(base, "Item2");
static void CreateMenuItem(lv_obj_t* parent, char * titleText)
lv_obj_t* base = lv_obj_create(parent, NULL);
lv_obj_set_size(base, 800, 50);
lv_obj_set_style(base, &titlestyle);
lv_obj_t* title = lv_label_create(base, NULL);
lv_label_set_text(title, titleText);
lv_obj_set_pos(title, 10, 2);
lv_obj_set_style(title, &titlestyle);
I want to remove the white space between each item. Simply changing the parents background colour to match the items is not suitable for my use.
