I am trying to get a “Hello World” app running on a smart watch based on atc1441/ATCwatch: Custom Arduino C++ firmware for the P8 and PineTime plus many more DaFit Smartwatches (github.com), which is using an older version of lvgl which was customized.
I’m using Arduino and a DaFit Watch Bootloader 23 board, which I pulled out of the Arduino portable ljunquera/arduino-smartwatch-boards: D6 Fitness Tracker Arduino Core for Nordic Semiconductor nRF5 based boards (github.com).
Printing Hello World to the watch screen.
Very simple compile of the code below with snippits taken from lvgl/LVGL_Arduino.ino at master · lvgl/lvgl (github.com)
void setup() {
// put your setup code here, to run once:
delay(500);
display_label();
and …
void display_label() {
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
/* Create simple label */
lv_obj_t *label = lv_label_create( lv_scr_act() );
lv_label_set_text( label, LVGL_Arduino.c_str() );
lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
/Users/[yyy]/Library/Arduino15/packages/nRF52D6Fitness/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld: region RAM overflowed with stack
collect2: error: ld returned 1 exit status
Using library lvgl at version 8.3.4 in folder: /Users/[yyy]/Documents/Arduino/libraries/lvgl
exit status 1
Error compiling for board DaFit Watch Bootloader 23.
