Redefined errors when using lv_conf.h
I am getting a ton(like over 50+) warnings(keyword warnings, not errors) when I create and include my lv_conf.h file. The file works and executes correctly, but I am getting way to many warnings to be able to debug effectively. The warning is a redefined warning, EX: LV_COLOR_16_SWAP redefined here(lv_conf.h), previous definiton located here:(lv_conf_internal.h)
ESP32S3 SPI, using ESP32 MCU, running ESP-IDF
tried both 8.3.8 and 8.3.3
To suppress these warnings
many types of suppression, none have worked. Changed location of lv_conf.h to main and include the LV_SIMPLE thing that locates it at main, did not work
No code really, more like project structure
Here is an example of the warning output:
In file included from c:\users\admin\documents\sq_project\we_done\we_did_it\components\esp32s3_spi\helper_display.hpp:26,
                 from C:/Users/Admin/Documents/sq_project/we_done/We_Did_It/main/main.hpp:7,
                 from C:/Users/Admin/Documents/sq_project/we_done/We_Did_It/main/main.cpp:11:
C:/Users/Admin/Documents/sq_project/we_done/We_Did_It/main/lv_conf.h:74: warning: "LV_MEMCPY_MEMSET_STD" redefined
   74 | #define LV_MEMCPY_MEMSET_STD 0
In file included from C:/Users/Admin/Documents/sq_project/we_done/We_Did_It/managed_components/lvgl__lvgl/src/misc/lv_log.h:16,
                 from C:/Users/Admin/Documents/sq_project/we_done/We_Did_It/managed_components/lvgl__lvgl/lvgl.h:25,
                 from C:/Users/Admin/Documents/sq_project/we_done/We_Did_It/main/main.cpp:9:
c:\users\admin\documents\sq_project\we_done\we_did_it\managed_components\lvgl__lvgl\src\lv_conf_internal.h:204: note: this is the location of the previous definition
  204 |         #define LV_MEMCPY_MEMSET_STD CONFIG_LV_MEMCPY_MEMSET_STD
No
Hi @Muzgog ,
Do you have the lines:
#ifndef LV_CONF_H
#define LV_CONF_H
at the beginning of your lv_conf.h file
and
#endif /*LV_CONF_H*/
at the end?
Kind Regards,
Pete
Hey Pete, thanks for the reply. Yes I do have those. I copied this straight from lv_conf_template. I’ve done this a million times without issues so I am wondering what I did differently this time.
The redefinition warnings would appear if lv_conf.h is included after lvgl.h, because LVGL would already have included lvgl_conf_internal.h, which defines these values.
Incidentally, lvgl_conf_internal.h does not define LV_CONF_H (it defines LV_CONF_INTERNAL_H), so there’s nothing to stop lv_conf.h from running in full.
