How can I change the color (opacity) of an image in a button (when pressed) properly?
Extra info - the image is LV_IMG_CF_ALPHA_4BIT - I want to have a different opacity per state of the button the image is inside of.
MCU/Processor/Board and compiler:
Testing with the lv_sim_eclipse_sdl demo (simulator via Eclipse)
LVGL version:
7.11.0
My initial try is to use a button w/ custom sizing/style + image on top and set recolor per state - then I can customize the button style appropriately, but the image doesn’t update:
So a button w/ border radius, etc, default vs pressed:
static lv_style_t btn_style, img_style;
// Style the button object:
lv_style_init(&btn_style);
lv_style_set_radius(&btn_style, LV_STATE_DEFAULT, 27);
lv_style_set_bg_opa(&btn_style, LV_STATE_DEFAULT, LV_OPA_100);
lv_style_set_bg_color(&btn_style, LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_style_set_bg_grad_color(&btn_style, LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_style_set_bg_grad_dir(&btn_style, LV_STATE_DEFAULT, LV_GRAD_DIR_VER);
lv_style_set_border_width(&btn_style, LV_STATE_DEFAULT, 2);
lv_style_set_border_color(&btn_style, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_bg_opa(&btn_style, LV_STATE_PRESSED, LV_OPA_50);
lv_style_set_border_opa(&btn_style, LV_STATE_PRESSED, LV_OPA_50);
lv_style_init(&img_style);
lv_style_set_image_recolor(&img_style, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_image_recolor_opa(&img_style, LV_STATE_DEFAULT, LV_OPA_100);
lv_style_set_image_recolor_opa(&img_style, LV_STATE_PRESSED, LV_OPA_50);
//create objects & assign style:
lv_obj_t *btn = lv_btn_create(parent, NULL);
lv_obj_set_event_cb(btn, cb);
lv_obj_add_style(btn, LV_BTN_PART_MAIN, &btn_style);
lv_obj_set_size(btn, 54, 54);
lv_obj_t *img = lv_img_create(btn, NULL);
lv_img_set_src(img, src_img);
lv_obj_add_style(img, LV_IMG_PART_MAIN, &img_style);
Just to mention, I ALSO tried imgbtn - but i wasn’t able to:
- Customize the initial image color in that case to not-black via image recolor for
LV_STATE_DEFAULT, and - also had issues customizing the background if i wanted it larger than the image. (like the above, where the image is just an icon / portion of the button, not the whole button).
