I have a windowed application where i want to receive keyboard events “globally” in the application
PC Linux using the lv_port_linux latest from master. Runing on the SDL backend.
Git submodule in port at HEAD detached at origin/release/v9.1
Receive keyboard events for the top level widget/window but key events seems supressed and not reaching the top window. Could this be some focus problem?
First i tried to attach a callback for the LV_EVENT_KEY event. This works if i have a text entry in the window and set the LV_OBJ_FLAG_EVENT_BUBBLE on it but without that i get no key events.
Then i tried adding a callback on the keyboard indev. This works partially but i get only zeroes for key and state. Further more key events seems to accumulate. First key press reports two events, which would be expected. But next press returns 4 events, next 6 events an so on.
Trying to attach to indev callback:
static void indev_cb(lv_indev_t* indev, lv_indev_data_t *data)
printf("Indev cb, type: %d key: %d state: %d\n", lv_indev_get_type(indev), data->key, data->state);
static void lv_linux_disp_init(void)
const int width = atoi(getenv("LV_SDL_VIDEO_WIDTH") ? : "800");
const int height = atoi(getenv("LV_SDL_VIDEO_HEIGHT") ? : "480");
display = lv_sdl_window_create(width, height);
lv_group_t *g = lv_group_create();
lv_group_set_default(g);
lv_indev_t *mouse = lv_sdl_mouse_create();
lv_indev_set_group(mouse, lv_group_get_default());
lv_indev_t *mousewheel = lv_sdl_mousewheel_create();
lv_indev_set_group(mousewheel, lv_group_get_default());
lv_indev_t *keyboard = lv_sdl_keyboard_create();
lv_indev_set_read_cb(keyboard, indev_cb);
lv_indev_set_group(keyboard, lv_group_get_default());
Attach event callback to main window:
static void event_cb(lv_event_t *e)
switch(lv_event_get_code(e))
case LV_EVENT_KEY:
printf("Got key: %d\n",lv_indev_get_key(lv_indev_active()));
break;
default:
printf("Unhandled event: %d\n", lv_event_get_code(e));
break;
static lv_event_dsc_t *evdsc;
static void setup(void)
lv_obj_t *parent = lv_screen_active();
#if 1
// With this enabled i get key events for the main window.
entry = lv_textarea_create(parent);
lv_obj_align(entry, LV_ALIGN_CENTER, 0, 50);
lv_obj_set_width(entry, 150);
lv_textarea_set_one_line(entry, true);
lv_textarea_set_max_length(entry, 12);
lv_obj_add_flag(entry, LV_OBJ_FLAG_EVENT_BUBBLE);
evdsc = lv_obj_add_event_cb(parent, event_cb, LV_EVENT_ALL, NULL);
