Reading analog value
Hi, I am trying to read an analog value from Pin A1 and display it on an external monitor. However, as soon as I have an analogRead(A1) in my code the screen turns white.
Additionally, I do not get anything on my Serial Monitor.
Aduino Portenta H7 / Arduino IDE 2.0
8.3.4
Being able to get values from analogRead() without the screen turning white.
So I tried to start the analogRead later with the help of an if statement. The display turns white as soon as I tried an analogRead once. It also does not display anything anymore after I have tried to do an analogRead. If I comment out the analogRead() the code works fine.
#include "Portenta_LittleVGL.h"
static lv_obj_t *label;
static lv_obj_t *secondlabel;
int counter = 0;
int analogValue = 0;
lv_timer_t * timer;
lv_timer_t * secondtimer;
static void updateCounterTimer(lv_timer_t *timer) {
  // Print the count to the Serial monitor
  Serial.println(counter);
  // Update the text of the label
  lv_label_set_text_fmt(label, "%d" , counter);
  // Increase the count number
  counter++;
static void analogread(lv_timer_t *secondtimer) {
  analogValue = analogRead(A1);
  Serial.println(analogValue);
  lv_label_set_text_fmt(secondlabel,"%d", analogValue);
void setup() {
  Serial.begin(115200);
  pinMode(A1,INPUT);
  // Initialize Portenta's video interface
  portenta_init_video();
  // Setting up the label making it a child of the screen
  label = lv_label_create(lv_scr_act());
  secondlabel = lv_label_create(lv_scr_act());
  // Set the label's text
  lv_label_set_text(label , "Counter");
  lv_label_set_text(secondlabel , "Analogvalue");
  // We move it to the center of the screen and align it centered
  lv_obj_align(secondlabel, LV_ALIGN_CENTER, 0, 20);
  // Create a timer to update the counter
  timer = lv_timer_create(updateCounterTimer, 1000, NULL);
  secondtimer = lv_timer_create(analogread, 1000, NULL);
void loop() {
  // put your main code here, to run repeatedly:
  Serial.print("Hello");
  lv_timer_handler();
