I’m have platformio Arduino based project that is running on esp32 with ili9341 display and using lvgl 7.7.2.
I’m having a problem with memory. At some random point in time application for some reason run out of memory. Look at the log. From 11% it will jump to 100% and then esp32 will restart. I have multiple screens but when this happens only dashboard screen is on and task for refreshing labels is running.
Error log:
used: 7780 ( 11 %), frag: 3 %, biggest free: 62396, max: 71680
used: 7752 ( 11 %), frag: 1 %, biggest free: 63916, max: 71680
used: 7764 ( 11 %), frag: 2 %, biggest free: 62776, max: 71680
used: 71668 (100 %), frag: 34 %, biggest free: 8, max: 71680
E (95622) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (95622) task_wdt: - IDLE0 (CPU 0)
E (95622) task_wdt: Tasks currently running:
E (95622) task_wdt: CPU 0: gui
E (95622) task_wdt: CPU 1: loopTask
E (95622) task_wdt: Aborting.
abort() was called at PC 0x400eeb97 on core 0
Backtrace: 0x4008da1c:0x3ffbe170 0x4008dc4d:0x3ffbe190 0x400eeb97:0x3ffbe1b0 0x40084839:0x3ffbe1d0 0x400e08f2:0x3fff5740 0x400dd0d0:0x3fff5760 0x400d6c25:0x3fff5850 0x400d7b9e:0x3fff58e0 0x400d7c48:0x3fff5930 0x400d7e05:0x3fff5950 0x400d8214:0x3fff59e0 0x400e0ad7:0x3fff5a30 0x400e0bbd:0x3fff5a50 0x400d1366:0x3fff5a70 0x4008a165:0x3fff5af0
#0 0x4008da1c:0x3ffbe170 in invoke_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:707
#1 0x4008dc4d:0x3ffbe190 in abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:707
#2 0x400eeb97:0x3ffbe1b0 in task_wdt_isr at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/task_wdt.c:252
#3 0x40084839:0x3ffbe1d0 in _xt_lowint1 at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/xtensa_vectors.S:1154
#4 0x400e08f2:0x3fff5740 in _lv_mem_buf_get at .pio/libdeps/esp32dev/lvgl/src/lv_misc/lv_mem.c:147
#5 0x400dd0d0:0x3fff5760 in draw_bg at .pio/libdeps/esp32dev/lvgl/src/lv_draw/lv_draw_rect.c:209
(inlined by) lv_draw_rect at .pio/libdeps/esp32dev/lvgl/src/lv_draw/lv_draw_rect.c:110
#6 0x400d6c25:0x3fff5850 in lv_obj_design at .pio/libdeps/esp32dev/lvgl/src/lv_core/lv_obj.c:3764
#7 0x400d7b9e:0x3fff58e0 in lv_refr_obj at .pio/libdeps/esp32dev/lvgl/src/lv_core/lv_refr.c:172
#8 0x400d7c48:0x3fff5930 in lv_refr_obj_and_children at .pio/libdeps/esp32dev/lvgl/src/lv_core/lv_refr.c:172
#9 0x400d7e05:0x3fff5950 in lv_refr_area_part at .pio/libdeps/esp32dev/lvgl/src/lv_core/lv_refr.c:172
#10 0x400d8214:0x3fff59e0 in lv_refr_area at .pio/libdeps/esp32dev/lvgl/src/lv_core/lv_refr.c:482
(inlined by) lv_refr_areas at .pio/libdeps/esp32dev/lvgl/src/lv_core/lv_refr.c:404
(inlined by) _lv_disp_refr_task at .pio/libdeps/esp32dev/lvgl/src/lv_core/lv_refr.c:203
#11 0x400e0ad7:0x3fff5a30 in lv_task_exec at .pio/libdeps/esp32dev/lvgl/src/lv_misc/lv_task.c:369
#12 0x400e0bbd:0x3fff5a50 in lv_task_handler at .pio/libdeps/esp32dev/lvgl/src/lv_misc/lv_task.c:369
#13 0x400d1366:0x3fff5a70 in gui_task(void*) at src/main.cpp:179
#14 0x4008a165:0x3fff5af0 in vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1)
Arduino ESP32 with ILI9341 display
Want to figure out how to debug this and to learn more about memory management.
Basically I was trying a lot of things but nothing works. I was trying to clean cache after lv_task_handler call.
lv_disp_clean_dcache(disp);
As I said I have dashboard and menu pages. In dashboard I will render few images and labels then I will create task to update labels. Task will be triggered every 100ms when dashboard is displayed on screen.
static void update_dasboard_labels_task(void * p) {
bool message_available = false;
struct RegulatorState state = receive_regulator_state(&message_available);
lv_mem_monitor(&mon);
lv_label_set_text_fmt(memory_label, "u: %6d (%3d %%), f: %3d %%, bf: %6d",
(int)mon.total_size - mon.free_size,
mon.used_pct,
mon.frag_pct,
(int)mon.free_biggest_size);
lv_label_set_text_fmt(up_time_label, "%d", millis());
if (message_available) {
static uint32_t prev_value = 0;
if (previous_state.requested_flow_temperature != state.requested_flow_temperature) {
lv_label_set_text_fmt(requested_flow_temperature_label, "R: %2.2f °C", state.requested_flow_temperature);
if (previous_state.flow_temperature != state.flow_temperature) {
lv_label_set_text_fmt(actual_flow_temperature_label, "A: %2.2f °C", state.flow_temperature);
if (previous_state.boiler_temperature != state.boiler_temperature) {
lv_label_set_text_fmt(boiler_flow_temperature_label, "B: %2.2f °C", state.boiler_temperature);
if (previous_state.outside_temperature != state.outside_temperature) {
lv_label_set_text_fmt(outside_temperature_label, "O: %2.2f °C", state.outside_temperature);
if (previous_state.radiator_pump_active != state.radiator_pump_active) {
lv_label_set_text_fmt(radiator_pump_active_label, "%d", state.radiator_pump_active);
if (previous_state.boiler_pump_active != state.boiler_pump_active) {
lv_label_set_text_fmt(boiler_pump_active_label, "%d", state.boiler_pump_active);
if (previous_state.state == NULL || strcmp(state.state, previous_state.state) != 0) {
lv_label_set_text_fmt(state_label, "%s", state.state);
if (previous_state.pid_output != state.pid_output) {
lv_label_set_text_fmt(pid_outuput_label, "PO %d", state.pid_output);
if (state.actuator_working) {
lv_obj_set_hidden(actuator_operating, true);
lv_obj_set_hidden(actuator_full_open, true);
lv_obj_set_hidden(actuator_full_closed, true);
if (state.actuator_direction == 0) {
lv_obj_set_hidden(actuator_arrow_left_icon, false);
lv_obj_set_hidden(actuator_arrow_right_icon, true);
} else {
lv_obj_set_hidden(actuator_arrow_left_icon, true);
lv_obj_set_hidden(actuator_arrow_right_icon, false);
} else {
lv_obj_set_hidden(actuator_operating, false);
if (state.actuator_dead_zone) {
lv_obj_set_hidden(actuator_full_open, false);
} else {
lv_obj_set_hidden(actuator_full_closed, false);
lv_msgbox_set_text(error_message_box, state.info_message);
if (strcmp(state.state, "ERROR") == 0) {
if (show_info_message) {
// lv_obj_set_hidden(error_message_box, false);
lv_obj_set_hidden(warining_label, false);
} else {
// lv_obj_set_hidden(error_message_box, true);
lv_obj_set_hidden(warining_label, true);
show_info_message = true;
if (is_connected_to_wifi_network()) {
lv_obj_set_hidden(wifi_icon, false);
if (is_connected_to_mqtt_broker()) {
lv_obj_set_hidden(mqtt_icon, false);
} else {
lv_obj_set_hidden(mqtt_icon, true);
} else {
lv_obj_set_hidden(wifi_icon, true);
previous_state = state;
Another problem possible memory leak
If you take a look at video you will see that every time when I switch from dashboard to menu and back every time used memory is increased and it will stay like that. If I do that 100+ times application will run out of memory.
// Open menu from dashboard page
static void open_menu_page(lv_obj_t * obj, lv_event_t event) {
lv_task_del(refr_task);
lv_obj_clean(lv_scr_act());
render_menu_page();
// Go back to dashboard page
static void back_icon_event_cb(lv_obj_t * obj, lv_event_t event)
render_dashboard_page();
