I want to make a drop down menu as android mobile phones have. Maybe with the gesture event, from top to bottom, I want to see some icons without changing the screen. Is that possible ?
It’s name is quick settings menu maybe.
As far as I understand - yes. You need to use pointer type input device and add gesture event to the screen. Drop down menu - is a simple container (base object) with identical objects (container with img & label in it).
