[Question]How to control the disp_flush row is even?
HI, Sirs:
  I have a special LCD that **switched the odd and even rows,**
  Normal LCD update rows:     0>1>2>3>4>5>6>7
  May LCD update rows:         1>0>3>2>5>4>7>6
  To normal display I try to switch odd and even row data in "my_disp_flush" function, before flash lcd.
  But sometimes the "lv_area_t *area" update rows is odd then I can not do the odd&even rows switch.
  **May I know how to control the "lv_area_t *area" always is even rows?**
       **How to control the "h" always is even?**
Thanks
You can use the round_cb
  • rounder_cb Round the coordinates of areas to redraw. E.g. a 2x2 px can be converted to 2x8. It can be used if the display controller can refresh only areas with specific height or width (usually 8 px height with monochrome displays).
On that same page you will find my_rounder_cb as an example.
