I used lvgl 8.2.
when I touch the screen and drag, _lv_indev_scroll_throw_handler() function will be called.
and lv_obj_scroll_by() function will be called by proc variable in _lv_indev_scroll_throw_handler(),
when we reviewed lv_obj_scroll_by function, I found out scroll animation is created and start it in lv_obj_scroll function.
however, When animation ends by the code below, the scroll_anim_ready_cb() function is called.
occure the LV_EVENT_SCROLL_END function from that function.
* lv_anim_set_ready_cb(&a, scroll_anim_ready_cb);
However, at the end of the _lv_indev_scroll_throw_handler() function,
a SCROLL_END event is generated again as shown below, and as a result, two scroll end events are generated.
Is this intended code?
static void scroll_anim_ready_cb(lv_anim_t * a)
lv_event_send(a->var, LV_EVENT_SCROLL_END, NULL);
void _lv_indev_scroll_throw_handler(_lv_indev_proc_t * proc)
lv_event_send(scroll_obj, LV_EVENT_SCROLL_END, indev_act);
if(proc->reset_query) return;
proc->types.pointer.scroll_dir = LV_DIR_NONE;
proc->types.pointer.scroll_obj = NULL;
