Put lv_conf.h inside my arduino Sketch Folder
I use LVGL 8.4 and Squareline Studio 1.50 and Arduino IDE 2.3.4
ESP32S3
8.4
Place lv_conf.h into sketch folder to include it into git and have different settings for different projects
Move and include - and searching a lot…
#include <lvgl.h>
#include "src/ui/ui.h"
#include "src/ui/ui_helpers.h"
My project is not small and works fine when the lv_conf.h is beside the libraries folder…
Have you tried as below?
#define LV_CONF_INCLUDE_SIMPLE
#include "lv_conf.h" // <-- path to your lv_conf.h
#include <lvgl.h>
Yes. I tryed a lot…
C:\Users\xx\Documents\Arduino\sketch\sketch.ino:40:10: fatal error: lvgl.h: No such file or directory
Even when i change the path of the lvgl.h it never works for me…
Try below;
In your sketch, add a new tab ‘build_opt.h’ and add the line below
-DLV_CONF_INCLUDE_SIMPLE
.ino file
#include <lvgl.h>
sorry for the late reply.
The first hint was already the solution. But it only works if the IDE is closed and restarted once after the change. Then the cache is probably rebuilt… I had the problem that I could not make any changes to the includes at all… Thanks for the hints.
