I am using a touch-screen LCD with an ILI9341 control chip. I have setup the chip in 8080 16-bit control mode, streaming 5-6-5 pixels over 16 data lines. I’ve tried 3 different ways of using partial mode of the ILI9341 (which allows you to describe the x/y/w/h region you’re going to stream pixels to).
Here’s the first thing I tried:
void my_disp_flush(lv_disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p)
int32_t x, y;
ILI9341_Partial(area->x1,area->y1,(area->x2-area->x1)+1,(area->y2-area->y1)+1);
lcd_draw_565_pixel(color_p->full);
color_p++;
lv_disp_flush_ready(disp); /* Indicate you are ready with the flushing*/
This doesn’t work. It draws the entire screen OK, but when I press buttons for instance they appear corrupted. Same with dragging a slider that updates a text label, the label appears corrupted.
Next, I tried this:
int32_t x, y;
ILI9341_Partial(x,y,1,1);
color_p++;
This does work, but is slow because it has to send commands over the bus to put the display in partial mode for each and every pixel.
So I tried this:
int32_t x, y;
ILI9341_Partial(area->x1,y,(area->x2-area->x1)+1,1);
color_p++;
This does work and is fast enough to be usable. However, I’d much rather use the 1st option as it would only require a single partial mode command per call to my_disp_flush versus calls for every line referenced in each call in my_disp_flush. I’m surprised option #1 didn’t work.
Unless there’s an option in the ILI9341 to reverse Y wrapping direction in partial mode I’m not sure what else would explain why #2 and #3 work but not #1
