Attaching styles in button strange behaviour.
ESP32
Simulator lvgl 8.3
Different styles for base state and pressed state. Cause the button has gradient to change bg from blue to red and button is checkable then after button is release you get a mix gradient that starts with blue and ends with red. Normal behaviour should have been that on check state the button is completely red.
Attaching 2 styles on LV_PART_MAIN | LV_STATE_DEFAULT for the main button and
LV_PART_MAIN | LV_STATE_PRESSED for pressed. Tried to read state of button on callback for any event and i get value of 38 and 39 or which seems to be PRESSED | FOCUSED | FOKUS_KEY (| CHECKED for 39). Maybe the main question i why the button comes immediatly with LV_STATE_FOCUS_KEY state and i can not get rid of it on the default state. Which means that the button is always focused even if i have a second object inside.
typedef enum {
START,
STOP,
SAVE,
LOAD
}ButtonTask;
typedef struct {
int32_t width;
int32_t height;
ButtonTask cbTask;
char* text;
bool checkable;
}button_t;
lv_obj_t* create_button(button_t btnConf){
static lv_style_t style_btn;
lv_style_init(&style_btn);
lv_style_set_width(&style_btn, btnConf.width);
lv_style_set_height(&style_btn, btnConf.height);
lv_style_set_outline_width(&style_btn, 0);
lv_style_set_radius(&style_btn, btnConf.height/2);
lv_style_set_bg_grad_color(&style_btn, lv_palette_darken(LV_PALETTE_BLUE, 4));
lv_style_set_bg_grad_dir(&style_btn, LV_GRAD_DIR_VER);
static lv_style_t style_btn_pr;
lv_style_init(&style_btn_pr);
lv_style_set_width(&style_btn_pr, btnConf.width);
lv_style_set_height(&style_btn_pr, btnConf.height);
lv_style_set_outline_width(&style_btn_pr, 0);
lv_style_set_radius(&style_btn_pr, btnConf.height/2);
lv_style_set_bg_color(&style_btn_pr, lv_palette_main(LV_PALETTE_RED));
lv_style_set_bg_grad_color(&style_btn_pr, lv_palette_darken(LV_PALETTE_RED, 4));
lv_style_set_bg_grad_dir(&style_btn_pr, LV_GRAD_DIR_VER);
lv_style_set_shadow_color(&style_btn_pr, lv_palette_main(LV_PALETTE_RED));
lv_style_set_shadow_width(&style_btn_pr, 2*btnConf.height);
lv_style_set_shadow_opa(&style_btn_pr, LV_OPA_COVER);
static const lv_style_prop_t btn_trans_props[] = {
LV_STYLE_BG_COLOR,
LV_STYLE_SHADOW_COLOR,
LV_STYLE_SHADOW_WIDTH,
LV_STYLE_SHADOW_OPA,
0, /*End marker*/
static lv_style_transition_dsc_t btn_trans;
lv_style_transition_dsc_init(&btn_trans, btn_trans_props, lv_anim_path_ease_out, 10, 0,NULL);
lv_style_set_transition(&style_btn_pr, &btn_trans);
lv_style_set_transition(&style_btn, &btn_trans);
lv_obj_t* btn=lv_btn_create(lv_scr_act());
lv_obj_t* label=lv_label_create(btn);
if(btnConf.checkable){
lv_obj_add_flag(btn, LV_OBJ_FLAG_CHECKABLE);
lv_label_set_text(label, btnConf.text);
lv_obj_center(label);
lv_obj_add_event_cb(btn, button_event_handler, LV_EVENT_VALUE_CHANGED, (void *) &btnConf.cbTask);
lv_obj_add_style(btn, &style_btn, LV_PART_MAIN | LV_STATE_DEFAULT | LV_STATE_FOCUS_KEY);
lv_obj_add_style(btn, &style_btn_pr, LV_PART_MAIN | LV_STATE_PRESSED );
return btn;
void button_event_handler(lv_event_t* e){
lv_event_code_t code=lv_event_get_code(e);
lv_obj_t* button = lv_event_get_target(e);
ButtonTask task= (ButtonTask)lv_event_get_user_data(e);
switch(button->state){
case LV_STATE_DEFAULT:
LV_LOG_USER("LV_STATE_DEFAULT");
break;
case LV_STATE_CHECKED:
LV_LOG_USER("LV_STATE_CHECKED");
break;
case LV_STATE_FOCUSED:
LV_LOG_USER("LV_STATE_FOCUSED");
break;
case LV_STATE_FOCUS_KEY:
LV_LOG_USER("LV_STATE_FOCUS_KEY");
break;
case LV_STATE_EDITED :
LV_LOG_USER("LV_STATE_EDITED");
break;
case LV_STATE_HOVERED:
LV_LOG_USER("LV_STATE_HOVERED");
break;
case LV_STATE_PRESSED:
LV_LOG_USER("LV_STATE_PRESSED");
break;
case LV_STATE_SCROLLED:
LV_LOG_USER("LV_STATE_SCROLLED");
break;
case LV_STATE_DISABLED:
LV_LOG_USER("LV_STATE_DISABLED");
break;
case LV_STATE_USER_1:
LV_LOG_USER("LV_STATE_USER_1");
break;
case LV_STATE_USER_2:
LV_LOG_USER("LV_STATE_USER_2");
break;
case LV_STATE_USER_3:
LV_LOG_USER("LV_STATE_USER_3");
break;
case LV_STATE_USER_4:
LV_LOG_USER("LV_STATE_USER_4");
break;
default:
printf("%d\n",button->state);
LV_LOG_USER( "non");
break;
switch (code) {
case LV_EVENT_PRESSED: /**< The object has been pressed*/
LV_LOG_USER("LV_EVENT_PRESSED");
break;
case LV_EVENT_PRESSING: /**< The object is being pressed (called continuously while pressing)*/
LV_LOG_USER("LV_EVENT_PRESSING");
break;
case LV_EVENT_PRESS_LOST: /**< The object is still being pressed but slid cursor/finger off of the object */
LV_LOG_USER("LV_EVENT_PRESS_LOST");
break;
case LV_EVENT_SHORT_CLICKED: /**< The object was pressed for a short period of time, then released it. Not called if scrolled.*/
LV_LOG_USER("LV_EVENT_SHORT_CLICKED");
break;
case LV_EVENT_LONG_PRESSED: /**< Object has been pressed for at least `long_press_time`. Not called if scrolled.*/
LV_LOG_USER("LV_EVENT_LONG_PRESSED");
break;
case LV_EVENT_LONG_PRESSED_REPEAT: /**< Called after `long_press_time` in every `long_press_repeat_time` ms. Not called if scrolled.*/
LV_LOG_USER("LV_EVENT_LONG_PRESSED_REPEAT");
break;
case LV_EVENT_CLICKED: /**< Called on release if not scrolled (regardless to long press)*/
LV_LOG_USER("LV_EVENT_CLICKED");
break;
case LV_EVENT_RELEASED: /**< Called in every cases when the object has been released*/
LV_LOG_USER("LV_EVENT_RELEASED");
break;
case LV_EVENT_SCROLL_BEGIN: /**< Scrolling begins. The event parameter is a pointer to the animation of the scroll. Can be modified*/
LV_LOG_USER("LV_EVENT_SCROLL_BEGIN");
break;
case LV_EVENT_SCROLL_END: /**< Scrolling ends*/
LV_LOG_USER("LV_EVENT_SCROLL_END");
break;
case LV_EVENT_SCROLL: /**< Scrolling*/
LV_LOG_USER("LV_EVENT_SCROLL");
break;
case LV_EVENT_GESTURE: /**< A gesture is detected. Get the gesture with `lv_indev_get_gesture_dir(lv_indev_get_act());` */
LV_LOG_USER("LV_EVENT_GESTURE");
break;
case LV_EVENT_KEY: /**< A key is sent to the object. Get the key with `lv_indev_get_key(lv_indev_get_act());`*/
LV_LOG_USER("LV_EVENT_KEY");
break;
case LV_EVENT_FOCUSED: /**< The object is focused*/
LV_LOG_USER("LV_EVENT_FOCUSED");
break;
case LV_EVENT_DEFOCUSED: /**< The object is defocused*/
LV_LOG_USER("LV_EVENT_DEFOCUSED");
break;
case LV_EVENT_LEAVE: /**< The object is defocused but still selected*/
LV_LOG_USER("LV_EVENT_LEAVE");
break;
case LV_EVENT_HIT_TEST:
LV_LOG_USER("LV_EVENT_HIT_TEST");
break;
default:
//LV_LOG_USER("NON");
break;
void main_view(){
button_t btnConf={
.width=144,
.height=32,
.cbTask = START,
.text = "The Start",
.checkable = true
lv_obj_t* button = create_button(btnConf);
lv_obj_center(button);
