I am porting LVGL 9.0 to my dsPIC33CK project, it was tough to understand the huge library, but I think it was worth it, anyway, I have everything going well and compiled correctly but the screen never has anything displayed, after some digging, I found that when the MCU enters lv_timer_handler(); function, it will never go out, and after some debugging, I discovered that the problem is in the following line inside lv_timer_exec(lv_timer_t * timer) ,
if(timer->timer_cb && original_repeat_count != 0) timer->timer_cb(timer);
dsPIC33CK256MP206, MPLAB X V6.2, XC_DSC
16 bit parallel interface, ili9341, 320x240 px
I wish to display something, it was a long week with no achievements yet ![]()
Make the heap bigger
Making the stack bigger
Navigating the very complex code with no evidence of what is happening
Here is the log until program stops doing anything useful
[User] (0.000, +0) main: ((Bismillah, a New Fresh Start)) main.c:58
[Info] (0.004, +4) lv_init: begin lv_init.c:139
[Info] (0.001, +1) lv_obj_create: begin lv_obj.c:100
[Trace] (0.005, +4) lv_obj_class_create_obj: Creating object with eac0 class on (nil) parent lv_obj_class.c:48
[Trace] (0.014, +9) lv_obj_class_create_obj: creating a screen lv_obj_class.c:57
[Trace] (0.021, +7) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.027, +6) lv_obj_constructor: finished lv_obj.c:349
[Info] (0.032, +5) lv_obj_create: begin lv_obj.c:100
[Trace] (0.036, +4) lv_obj_class_create_obj: Creating object with eac0 class on (nil) parent lv_obj_class.c:48
[Trace] (0.046, +10) lv_obj_class_create_obj: creating a screen lv_obj_class.c:57
[Trace] (0.054, +8) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.059, +5) lv_obj_constructor: finished lv_obj.c:349
[Info] (0.064, +5) lv_obj_create: begin lv_obj.c:100
[Trace] (0.069, +5) lv_obj_class_create_obj: Creating object with eac0 class on (nil) parent lv_obj_class.c:48
[Trace] (0.079, +10) lv_obj_class_create_obj: creating a screen lv_obj_class.c:57
[Trace] (0.086, +7) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.091, +5) lv_obj_constructor: finished lv_obj.c:349
[Info] (0.097, +6) lv_obj_create: begin lv_obj.c:100
[Trace] (0.101, +4) lv_obj_class_create_obj: Creating object with eac0 class on (nil) parent lv_obj_class.c:48
[Trace] (0.111, +10) lv_obj_class_create_obj: creating a screen lv_obj_class.c:57
[Trace] (0.118, +7) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.123, +5) lv_obj_constructor: finished lv_obj.c:349
[Info] (0.639, +516) lv_obj_create: begin lv_obj.c:100
[Trace] (0.643, +4) lv_obj_class_create_obj: Creating object with eac0 class on (nil) parent lv_obj_class.c:48
[Trace] (0.652, +9) lv_obj_class_create_obj: creating a screen lv_obj_class.c:57
[Trace] (0.659, +7) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.665, +6) lv_obj_constructor: finished lv_obj.c:349
[Info] (0.670, +5) lv_button_create: begin lv_button.c:50
[Trace] (0.675, +5) lv_obj_class_create_obj: Creating object with f07a class on 575e parent lv_obj_class.c:48
[Trace] (0.685, +10) lv_obj_class_create_obj: creating normal object lv_obj_class.c:81
[Trace] (0.693, +8) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.698, +5) lv_obj_constructor: finished lv_obj.c:349
[Trace] (0.703, +5) lv_button_constructor: begin lv_button.c:63
[Trace] (0.709, +6) lv_button_constructor: finished lv_button.c:68
[Info] (0.715, +6) lv_label_create: begin lv_label.c:83
[Trace] (0.720, +5) lv_obj_class_create_obj: Creating object with dbe4 class on 575e parent lv_obj_class.c:48
[Trace] (0.729, +9) lv_obj_class_create_obj: creating normal object lv_obj_class.c:81
[Trace] (0.737, +8) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.742, +5) lv_obj_constructor: finished lv_obj.c:349
[Trace] (0.747, +5) lv_label_constructor: begin lv_label.c:623
[Trace] (0.753, +6) lv_label_constructor: finished lv_label.c:650
[Info] (0.760, +7) lv_slider_create: begin lv_slider.c:68
[Trace] (0.764, +4) lv_obj_class_create_obj: Creating object with f362 class on 575e parent lv_obj_class.c:48
[Trace] (0.774, +10) lv_obj_class_create_obj: creating normal object lv_obj_class.c:81
[Trace] (0.782, +8) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.786, +4) lv_obj_constructor: finished lv_obj.c:349
[Trace] (0.792, +6) lv_bar_constructor: begin lv_bar.c:228
[Trace] (0.798, +6) lv_bar_constructor: finished lv_bar.c:249
[Info] (0.803, +5) lv_obj_create: begin lv_obj.c:100
[Trace] (0.807, +4) lv_obj_class_create_obj: Creating object with eac0 class on (nil) parent lv_obj_class.c:48
[Trace] (0.817, +10) lv_obj_class_create_obj: creating a screen lv_obj_class.c:57
[Trace] (0.825, +8) lv_obj_constructor: begin lv_obj.c:320
[Trace] (0.830, +5) lv_obj_constructor: finished lv_obj.c:349
[Trace] (0.835, +5) lv_timer_handler: begin lv_timer.c:65
[Trace] (0.840, +5) lv_timer_exec: calling timer callback: 39a lv_timer.c:298
[Trace] (0.847, +7) _lv_display_refr_timer: begin lv_refr.c:327
[Trace] (0.852, +5) lv_obj_update_layout: Layout update begin lv_obj_pos.c:301
[Trace] (0.862, +10) lv_obj_update_layout: Layout update end lv_obj_pos.c:304
[Trace] (0.867, +5) lv_obj_update_layout: Layout update begin lv_obj_pos.c:301
[Trace] (0.875, +8) lv_obj_update_layout: Layout update end lv_obj_pos.c:304
[Trace] (0.881, +6) lv_obj_update_layout: Layout update begin lv_obj_pos.c:301
[Trace] (0.888, +7) lv_obj_update_layout: Layout update end lv_obj_pos.c:304
[Trace] (0.895, +7) lv_obj_update_layout: Layout update begin lv_obj_pos.c:301
[Trace] (0.902, +7) lv_obj_update_layout: Layout update end lv_obj_pos.c:304
[Trace] (0.908, +6) lv_obj_update_layout: Layout update begin lv_obj_pos.c:301
[Trace] (0.915, +7) lv_obj_update_layout: Layout update end lv_obj_pos.c:304
[Trace] (0.922, +7) wait_for_flushing: begin lv_refr.c:1076
[Trace] (0.928, +6) wait_for_flushing: end lv_refr.c:1090
