In my project, I’m using LVGL 8.0 and a Spinbox widget with an encoder in one of the screens. The encoder is set up as an input device and works well with other widgets and screens.
The Spinbox widget functions as intended with the exception of this strange problem: after a while, it simply stops updating the values when the encoder is turned left or “anticlockwise” (but continues to function normally when the encoder is turned right or “clockwise”).
As far as my debugging goes, ‘LV KEY LEFT’ is not even getting an event. Here’s my Spinbox event handler code:
void SpinboxEventHandler_v(lv_event_t * e)
uint32_t u32_key;
if (event_code == LV_EVENT_KEY)
u32_key = lv_event_get_key(e);
if (u32_key == LV_KEY_LEFT)
lv_spinbox_decrement(spinbox);
/* Project specific code */
else if (u32_key == LV_KEY_RIGHT)
lv_spinbox_increment(spinbox);
} // if (event_code == LV_EVENT_KEY)
Is there anything I’m missing? Have you run into this problem before? Do you have any suggestions for resolving it? Any assistance with this issue would be greatly appreciated!
Thanks.
