Problem with spinbox, text move up and down when size is not that large
Qt simulator
V8.4
smaller spin box which text’s is not going up and down on change
static lv_obj_t * spinbox;
static void lv_spinbox_increment_event_cb(lv_event_t * e)
if(code == LV_EVENT_SHORT_CLICKED || code == LV_EVENT_LONG_PRESSED_REPEAT) {
lv_spinbox_increment(spinbox);
static void lv_spinbox_decrement_event_cb(lv_event_t * e)
lv_spinbox_decrement(spinbox);
void lv_example_spinbox_1(void)
spinbox = lv_spinbox_create(lv_scr_act());
// I have added only this line
lv_obj_set_size(spinbox,100,30);
lv_spinbox_set_range(spinbox, -1000, 25000);
lv_spinbox_set_digit_format(spinbox, 5, 2);
lv_spinbox_step_prev(spinbox);
lv_obj_set_width(spinbox, 100);
lv_obj_center(spinbox);
lv_coord_t h = lv_obj_get_height(spinbox);
lv_obj_t * btn = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn, h, h);
lv_obj_align_to(btn, spinbox, LV_ALIGN_OUT_RIGHT_MID, 5, 0);
lv_obj_set_style_bg_img_src(btn, LV_SYMBOL_PLUS, 0);
lv_obj_add_event_cb(btn, lv_spinbox_increment_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align_to(btn, spinbox, LV_ALIGN_OUT_LEFT_MID, -5, 0);
lv_obj_set_style_bg_img_src(btn, LV_SYMBOL_MINUS, 0);
lv_obj_add_event_cb(btn, lv_spinbox_decrement_event_cb, LV_EVENT_ALL, NULL);
As you see, the place of number has changed out of nothing. Why is it so?
