lv_style_set_border_side(&list_style, LV_STATE_DEFAULT, LV_BORDER_SIDE_RIGHT);
When the bottom layer has components displayed, the color will fade when redrawing,see blow:
void init_list_style(void)
lv_style_init(&list_style);
lv_style_set_bg_color(&list_style, LV_STATE_FOCUSED, LV_COLOR_MAKE(128, 128, 128));
lv_style_set_bg_color(&list_style, LV_STATE_DEFAULT, LV_COLOR_MAKE(48, 48, 48));
lv_style_set_bg_opa(&list_style, LV_STATE_DEFAULT, LV_OPA_70);
#if 1
lv_style_set_border_width(&list_style, LV_STATE_DEFAULT, 14);
**lv_style_set_border_side(&list_style, LV_STATE_DEFAULT, LV_BORDER_SIDE_RIGHT);**
lv_style_set_border_opa(&list_style, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_border_color(&list_style, LV_STATE_DEFAULT, LV_COLOR_MAKE(32, 32, 32));
lv_style_set_border_color(&list_style, LV_STATE_FOCUSED, LV_COLOR_MAKE(64, 64, 64));
lv_style_set_value_font(&list_style, LV_STATE_DEFAULT, &arial_bd_20);
lv_style_set_value_opa(&list_style, LV_STATE_DEFAULT, LV_OPA_TRANSP);
lv_style_set_value_opa(&list_style, LV_STATE_CHECKED, LV_OPA_COVER);
lv_style_set_value_color(&list_style, LV_STATE_DEFAULT, LV_COLOR_YELLOW);
lv_style_set_value_align(&list_style, LV_STATE_DEFAULT, LV_ALIGN_IN_RIGHT_MID);
lv_style_set_value_ofs_x(&list_style, LV_STATE_DEFAULT, -1);
lv_style_set_value_str(&list_style, LV_STATE_DEFAULT, "●");
lv_obj_t * create_list(int16_t x, uint8_t index, uint8_t max, const lv_img_dsc_t *pImg[])
#define ML_Y 192
uint8_t config = menu_config[index];
int16_t w = (max==4) ? (100) : (52);
lv_obj_t * parent = lv_cont_create(lv_scr_act(), NULL);
lv_obj_set_pos(parent, x, ML_Y - max * 32);
lv_obj_set_size(parent, w, 32 * max);
lv_obj_set_style_local_bg_opa(parent, LV_CONT_PART_MAIN, LV_STATE_DEFAULT, LV_OPA_TRANSP);
lv_cont_set_layout(parent, LV_LAYOUT_COLUMN_MID);
//lv_cont_set_fit(parent, LV_FIT_TIGHT);
lv_group_add_obj(kb_group, parent);
lv_group_focus_obj(parent);
lv_obj_set_event_cb(parent, list_sel_event_handler);
for (uint8_t i = 0; i < max; i++)
lv_obj_t *obj_bgd1 = lv_obj_create(parent, NULL);
lv_obj_set_size(obj_bgd1, w, 32);
lv_obj_add_style(obj_bgd1, LV_OBJ_PART_MAIN, &list_style);
lv_obj_set_user_data(obj_bgd1, &index_tb[i]);
if (config & 0x80)
if (config & (1 << i))
obj_bgd1->state = LV_STATE_CHECKED;
if (i==0)
obj_bgd1->state |= LV_STATE_FOCUSED;
obj_list_focus = obj_bgd1;
else if (i == config)
obj_bgd1->state = LV_STATE_FOCUSED | LV_STATE_CHECKED;
if(pImg == NULL)
lv_obj_t *label = lv_label_create(obj_bgd1, NULL);
lv_obj_set_style_local_text_font(label, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, &arial_bd_14);
lv_label_set_text_fmt(label, "%d%%", 25*i);
lv_obj_align(label, NULL, LV_ALIGN_CENTER, -7, 0); //Must be put behind
lv_obj_t * img1 = lv_img_create(obj_bgd1, NULL);
lv_img_set_src(img1, pImg[i]);
lv_obj_align(img1, NULL, LV_ALIGN_CENTER, -7, 0); //Must be put behind
menu_index = index;
return parent;
