I’am trying to use fallback font w/ buil-in font to extend extra symbol choice.
I have created a new font w/ FonteAwesome. It works fine when i use it directly w/ lv_obj_set_style_font_text.
In the declaration of the default font of my project (montserrat_12) i added this line :
.dsc = &font_dsc, /*The custom font data. Will be accessed by get_glyph_bitmap/dsc */
.fallback = & cadenas
I don’t get compilation error and fallback member of the font montserrat_12 is ok (adress of cadenas font).
But when i add symbol from cadenas fonte in a label text i get only a space caracter…
What’s wrong w/ my code?
Best regards
Please attach the fonts and a minimal code to reproduce the issue.
SYMBOLES_XTRA.c (6.3 KB)
Well, all my extended symbole fit in the attached fonte.
I created al the define symbol w/ UTF8 bytes
the default font is montserrat_12 and i added this line in the initialization parte of the font struct :
.fallback = &SYMBOLES_XTRA
if i change the font of a label :
lv_obj_set_style_text_font(Cadenas_g,&SYMBOLES_XTRA,0);
lv_label_set_text(Cadenas_g,CADENAS_FERME) ;
i get the right symbol.
but i add the symbol in the text of a label w/ default fontt i get a space :
lv_label_set_text(Label,“Testing Fall back” CADENAS_FERME) ;
Best Regards
What is the value of CADENAS_FERME?
hi
#define CADENAS_FERME “\xEF\x80\xA3”
it’s the caracter w/ ID unicode 0xF023 in the Font Awesome!!
you can see it in the bottom corners of the picture :
It works for me like this:
lv_font_montserrat_12.c:
extern lv_font_t SYMBOLES_XTRA;
/*Initialize a public general font descriptor*/
#if LV_VERSION_CHECK(8, 0, 0)
const lv_font_t lv_font_montserrat_12 = {
#else
.get_glyph_dsc = lv_font_get_glyph_dsc_fmt_txt, /*Function pointer to get glyph's data*/
.get_glyph_bitmap = lv_font_get_bitmap_fmt_txt, /*Function pointer to get glyph's bitmap*/
.line_height = 15, /*The maximum line height required by the font*/
.base_line = 3, /*Baseline measured from the bottom of the line*/
#if !(LVGL_VERSION_MAJOR == 6 && LVGL_VERSION_MINOR == 0)
.subpx = LV_FONT_SUBPX_NONE,
#if LV_VERSION_CHECK(7, 4, 0) || LVGL_VERSION_MAJOR >= 8
.underline_position = -1,
.underline_thickness = 1,
.fallback = &SYMBOLES_XTRA,
.dsc = &font_dsc /*The custom font data. Will be accessed by `get_glyph_bitmap/dsc` */
main.c
#define CADENAS_FERME "\xEF\x80\xA3"
lv_obj_set_style_text_font(label,&lv_font_montserrat_12,0);
lv_label_set_text(label,"a"CADENAS_FERME"b");
Hi…
I’ dont know what was wrong w/ my lvgl’s previous version but w/ the ultimate version (today) it 'all ok!!!
In few week i’ll present my projet w/ arduino due and RA8875 screen.
Best regards
