Problem in building simulator demo
I am using macOS 14.2. And tried to run the simulator demo but got 600 plus errors. Errors are not make sense because, on the pointed line, it is correct. So don’t know what I am missing.
What I did is first installed Eclipse CDT then installed STL using the command brew install stl2
then cloned the repo using the below git command
git clone --recursive https://github.com/lvgl/lv_port_pc_eclipse
imported that project in eclipse CDT and pressed build button but getting 600 errors.
MacOS simulator eclipse
Run the simulator demo
Tried to put the SDL2 folder in the side project and change the path
Screenshot
Have you tried the PlatformIO port?
