When drawing a label on a canvas I get artifacts on glyphs. In details they have holes on it through which the underlying layer is visible. It happens both with a freetype font and with builtin montserrat.
It looks like the holes all have the same size and form factor, small lines of the same amount of pixels.
Custom iMXRT1052-based board with PXP running, working on IAR 9.10 and FreeRTOS Kernel V10.4.3 LTS Patch 2.
LVGL 9.1
I’m trying to draw label on Canvas so that I can shrink text by scaling the resulting buffer.
The attached snippet only includes the main rendering, not the shrinking which is yet to be done.
I tried:
- not to call fill_bg function
- init buffer for canvas in several ways
- moving the canvas on different position
- resizing the canvas
- montserrat font
This snippet is executed only once in my program.
//Create Canvas for PI label
symbolsArea.piLbl = lv_canvas_create(screen);
AllocateBufferForCanvas(&symbolsArea.piLblBuf, layout->piWidget.sizePos.w, layout->piWidget.sizePos.h);
lv_canvas_set_draw_buf(symbolsArea.piLbl, &symbolsArea.piLblBuf);
lv_obj_set_pos(symbolsArea.piLbl, layout->piWidget.sizePos.x, layout->piWidget.sizePos.y);
lv_obj_set_size(symbolsArea.piLbl, layout->piWidget.sizePos.w, layout->piWidget.sizePos.h);
lv_canvas_fill_bg(symbolsArea.piLbl, lv_color_make(0, 0, 0), LV_OPA_TRANSP);
//Init layer
lv_canvas_init_layer(symbolsArea.piLbl, &symbolsArea.layer);
//Create label descriptor for canvas
lv_draw_label_dsc_init(&symbolsArea.piLblDsc);
symbolsArea.piLblDsc.color = lv_color_make(layout->piWidget.foreColor.r, layout->piWidget.foreColor.g, layout->piWidget.foreColor.b);
symbolsArea.piLblDsc.align = GetHorAlign(layout->piWidget.alignTextH);
symbolsArea.piLblDsc.font = info->font;
symbolsArea.piLblDsc.text = "GG";
lv_area_t piLblArea = { 0, 0, layout->piWidget.sizePos.w - 1, layout->piWidget.sizePos.h - 1 };
lv_draw_label(&symbolsArea.layer, &symbolsArea.piLblDsc, &piLblArea);
lv_canvas_finish_layer(symbolsArea.piLbl, &symbolsArea.layer);
I noticed that:
- when stepping in debug through the latest 2 lines, and then run the PC, the problems doesn’t appear
- I have a user menu that can be opened on top of that canvas. If I open it and then close it, the symbols are cleaned from the artifact.
