STM32F407
7
how to add Russian to the library?
For your firmware you really need only the two files in folder ‘src’.
Whereas the name lv_i18n.template.c is chosen a bit unfortunate.
I would prefer lv_i18n.c and put the implementation (for a specific language) in a different file.
For a clearly number of textes the approch as it is described within the i18n page is OK,
but for a larger number of text (and languages) I would prefer a different approach.
For my PC apps I use poedit, which then produces binary files (mo files) which contains the text within a table which is searchable with a binary tree algorithm.
But currently the lvgl’s implementation doesn’t support mo files which for example would be located on a SD card. That’s something which is on my plan… some day.
For further information use aunt G… E.g search for i18n gettext poedit
