Possible with lvgl 8.4 to read assets with arduino sd library?
before i try around…
I use lvgl 8.4 and ESP32S3 Board. I can read and write on SD-Card using the SD Library from Arduino. Works fine.
I try a lot to read assets from sd-card, even as png and also as binary from converter.
In the latest release it is directly possible but for now i use 8.4 and there is no real reason to update for me, because all other things works fine.
Question: Is the a way to use it or is the update to 9.2 a must for that?
Thanks in advance.
I don’t understand the question very well, but if you are good with version 8.4, then keep using it because in version lvgl 9, as far as I know, there are quite a few changes in functions, structures and lv_config, but it’s still worth a try if you want.
Finally i get it to work. With 8.4 and SD Library. If someone need help, ask me.
Hey Alex! I’m struggling with this exact same problem. Mind giving me a hand? :slight_smile:
yes sure. Sorry for late reply. I have now a library to load images from SD and use it in LVGL
Hi again Alex,
I was finally able to get it running by adapting the lvgl 9 arduino sd card code to version 8. If somebody needs it i’ll be happy to asist, since i had to modify a few files to get it running correctly.
I’m using 8.3 and have issue loading images from SD. How were you able to resolve this?
Hi Alex,
I am glad to see that you succeed where I am struggling.
I am using Arduino Ide with LVGL 8.4 & Elecrow DIS8070H.
The goal I want to achieve is to visualize on a 800x480 display,BMP or JPG images stored into the SD.
Just to tell you the actual status:
  • SD is connected
  • I can list the files into the SD
  • I can run LVGL widgets on the screen
  • I can visualize images in bmp format not using LVGL
  • I can visualize image in C format converted through the online converter
  • I AM NOT ABLE TO VISUALIZE IMAGE DIRECTLY FROM THE SD using LVGL.
    I really am not able to even understand where I am doing wrong ( Most probably it is something very basic )
    Can you share an Arduino sketch just doing this?
    Thanks
Alex, Olá.
Poderia compartilhar como resolveu?
Não estou conseguindo ler imagem do SDcard com lvgl 8.4.0.
is your problem still there? I can perhaps help
