ESP32 - M5Stack Xtensa GCC 8.2
What do you experience?
If I modify the esp32 example to use dynamically allocated buffers instead of static, I experience a panic the first time that lv_task_handler runs. Inspecting the core dump, the stack tends to move around a bit in the lvgl code-base as I change my application code. This feels like a memory overrun bug, and it makes me worried the same overrun is happening in the static memory space it just doesn’t overwriting anything we happen to be using at the moment.
What do you expect?
The demo to run the same as with static buffers.
Add a code snippet to reproduce the issue in the simulator. It should contain only the relevant code which can be compiled. Bug reports without code snippets or with erroneous code snippets will not be reviewed.
Use the ```c and ``` tags to format your code:
If I change the demo main.c:
(e.g. this ref)
static lv_color_t buf1[DISP_BUF_SIZE];
static lv_color_t buf2[DISP_BUF_SIZE];
lv_disp_buf_init(&disp_buf, buf1, buf2, DISP_BUF_SIZE);
To
lv_color_t* buf1 = (lv_color_t*)lv_mem_alloc(DISP_BUF_SIZE);
lv_color_t* buf2 = (lv_color_t*)lv_mem_alloc(DISP_BUF_SIZE);
lv_mem_assert(buf1);
lv_mem_assert(buf2);
In the core dump:
Thank you
