ESP32-S#-LCD-EV-BOARD2 (800x480)
v9.2
What I have achieved so far?
screen configured, objects created including containers, chart, scales, buttons
Positioning & drawing the left & right vertical scales, in correct position and updating
Positioning & drawing the bottom horizontal scale, in correct position and updating when required
Buttons correctly positioned and working, selecting between the 5 different screens
Reduce the area of the chart, as demarcated by the horizontal and vertical divider lines, to fit inside VL, VR & HB scales
Ensure the extreme hor/ver divider lines line up with the lowest and highest values on the scales
Everything I could think of or imagine, too many to mention.
Have not yet put it through the simulator since nothing indicates a hardware problem
The code is part of a much larger project so have not been able separate out an independent snippet to compile.
Since the problem must be very simple, for anyone other than a complete LVGL beginner like myself, I trust the snippets below will be sufficient to identify the cause.
#define lvglBORDER_WID 0
#define lvglBUTTON_NUM 5
#define lvglBUTTON_PY 32 // pixel height allowed for buttons
// text window
#define lvglWINDOW_PX (halLCD_MAX_PX - (2*lvglBORDER_WID))
#define lvglWINDOW_PY (halLCD_MAX_PY - (2*lvglBORDER_WID) - lvglBUTTON_PY)
#define lvglWINDOW_TLX lvglBORDER_WID
#define lvglWINDOW_TLY lvglBORDER_WID
// scales
#define lvglSCALE_PX 32 // VERtical scale WIDTH
#define lvglSCALE_PY 32 // HORizontal scale HEIGHT
// scale LEFT VERTICAL
#define lvglSCALE0_PX lvglSCALE_PX
#define lvglSCALE0_PY (lvglWINDOW_TLY + lvglWINDOW_PY - lvglSCALE_PY)
#define lvglSCALE0_TLX lvglWINDOW_TLX
#define lvglSCALE0_TLY lvglWINDOW_TLY
// scale RIGHT VERTICAL
#define lvglSCALE1_PX lvglSCALE_PX
#define lvglSCALE1_PY (lvglWINDOW_TLY + lvglWINDOW_PY - lvglSCALE_PY)
#define lvglSCALE1_TLX (lvglWINDOW_TLX + lvglWINDOW_PX - lvglSCALE1_PX)
#define lvglSCALE1_TLY lvglWINDOW_TLY
// scale BOTTOM HORIZONTAL
#define lvglSCALE2_PX (lvglWINDOW_TLX + lvglWINDOW_PX - lvglSCALE0_PX - lvglSCALE1_PX)
#define lvglSCALE2_PY lvglSCALE_PY
#define lvglSCALE2_TLX (lvglSCALE0_TLX + lvglSCALE0_PX)
#define lvglSCALE2_TLY (lvglSCALE0_TLY + lvglSCALE0_PY)
// chart object
#define lvlglCHART_MARGIN_X 0
#define lvlglCHART_MARGIN_Y 0
#define lvglCHART_PX (lvglWINDOW_PX - lvlglCHART_MARGIN_X)
#define lvglCHART_PY (lvglWINDOW_PY - lvlglCHART_MARGIN_Y)
// button object(s)
#define lvglBUTTON_TLX lvglBORDER_WID
#define lvglBUTTON_TLY (lvglWINDOW_TLY + lvglWINDOW_PY)
#define lvglBUTTON_PX (halLCD_MAX_PX - (2*lvglBORDER_WID))
#define lvglBUTTON_PX_EA (lvglBUTTON_PX / lvglBUTTON_NUM)
const lv_style_const_prop_t ConstDefault[] = {
LV_STYLE_CONST_WIDTH(halLCD_MAX_PX),
LV_STYLE_CONST_HEIGHT(halLCD_MAX_PY),
LV_STYLE_CONST_BORDER_WIDTH(0),
LV_STYLE_CONST_BORDER_SIDE(0),
LV_STYLE_CONST_PAD_BOTTOM(0),
LV_STYLE_CONST_PAD_LEFT(0),
LV_STYLE_CONST_PAD_RIGHT(0),
LV_STYLE_CONST_PAD_TOP(0),
LV_STYLE_CONST_BG_OPA(LV_OPA_100),
LV_STYLE_CONST_TEXT_OPA(LV_OPA_100),
LV_STYLE_CONST_BG_COLOR(lvglCOLOR_BLACK),
LV_STYLE_CONST_TEXT_COLOR(lvglCOLOR_WHITE),
LV_STYLE_CONST_TEXT_FONT((const void *)&lv_font_unscii_8),
LV_STYLE_CONST_PROPS_END
LV_STYLE_CONST_INIT(sStyleDefault, ConstDefault);
const lv_style_const_prop_t ConstInfoWin[] = {
LV_STYLE_CONST_WIDTH(lvglWINDOW_PX),
LV_STYLE_CONST_HEIGHT(lvglWINDOW_PY),
// LV_STYLE_CONST_FLEX_FLOW(LV_FLEX_FLOW_COLUMN),
LV_STYLE_CONST_INIT(sStyleInfoWin, ConstInfoWin);
const lv_style_const_prop_t ConstChart[] = {
LV_STYLE_CONST_WIDTH(lvglCHART_PX),
LV_STYLE_CONST_HEIGHT(lvglCHART_PY),
// LV_STYLE_CONST_FLEX_GROW(1),
// LV_STYLE_CONST_ALIGN(LV_ALIGN_TOP_MID),
LV_STYLE_CONST_RADIUS(0),
LV_STYLE_CONST_INIT(sStyleChart, ConstChart);
scale_var_t * psGuiCreateScale(lv_obj_t * poChart, const scale_cfg_t * psScC, int axis) {
scale_var_t * psScV = (scale_var_t *) calloc(1, sizeof(scale_var_t));
psScV->poScale = lv_scale_create(poChart);
IF_myASSERT(debugRESULT, psScV->poScale);
lv_scale_set_mode(psScV->poScale, axis2LvMode[axis]);
lv_scale_set_total_tick_count(psScV->poScale, psScC->TotalTick);
lv_scale_set_major_tick_every(psScV->poScale, psScC->MajorEvery);
// set position & size
lv_obj_set_pos(psScV->poScale, psScC->sCoord.tlX, psScC->sCoord.tlY);
lv_obj_set_size(psScV->poScale, psScC->sCoord.widX, psScC->sCoord.widY);
// set lengths & colors for major and minor ticks
lv_obj_set_style_length(psScV->poScale, psScC->MElength, LV_PART_INDICATOR);
lv_obj_set_style_text_color(psScV->poScale, psScC->Color, LV_PART_INDICATOR);
lv_obj_set_style_length(psScV->poScale, psScC->TTlength, LV_PART_ITEMS);
if (axis <= axisVR) { // Left & Right vertical scales
psScV->poSeries = lv_chart_add_series(poChart, psScC->Color, axis2LvAxis[axis]);
lv_chart_set_range(poChart, axis2LvAxis[axis], psScC->LoVal.i32, psScC->HiVal.i32);
} else { // Bottom & Top horizontal scales
// lv_obj_set_style_pad_hor(psScV->poScale, lv_chart_get_first_point_center_offset(poChart), LV_PART_MAIN);
if (psScC->pcFmt) { // custom format requested, allocate buffers and initialise
psScV->count = (psScC->TotalTick / psScC->MajorEvery) + 1; // number of labels
psScV->sBuf = psScV->count * psScC->SizeFmt; // size of label buffer
IF_myASSERT(debugTRACK, psScV->sBuf < 16384);
psScV->pcBuf = (char *) calloc(psScV->count, psScC->SizeFmt); // allocate label buffer
psScV->paLabels = (const char **) calloc(psScV->count+1, sizeof(const char *)); // 1 extra
vGuiUpdateScale(psScC, psScV, (x32_t) 0, (x32_t) (psScC->MajorEvery * psScC->Points));
} else {
lv_scale_set_range(psScV->poScale, psScC->LoVal.i32, psScC->HiVal.i32);
lv_scale_set_label_show(psScV->poScale, true);
psScV->tReload = psScC->Intvl; // start the timer at 0 for immediate 1st update
return psScV;
void vGuiInit(void) {
sGuiVar.poDisplay = bsp_display_start();
IF_myASSERT(debugRESULT, sGuiVar.poDisplay != 0);
lv_tick_set_cb(xGuiGetMillis);
lv_log_register_print_cb(vGuiSyslog);
lvgl_port_lock(0);
{ // Get & configure top level screen
sGuiVar.poScreen = lv_display_get_screen_active(sGuiVar.poDisplay);
// sGuiVar.poScreen = lv_obj_create(lv_screen_active());
IF_myASSERT(debugRESULT, sGuiVar.poScreen);
lv_obj_remove_style_all(sGuiVar.poScreen);
lv_obj_add_style(sGuiVar.poScreen, &sStyleDefault, LV_PART_MAIN);
{ // Create Text object
sGuiVar.poText = lv_label_create(sGuiVar.poScreen);
// sGuiVar.poText = lv_textarea_create(sGuiVar.poScreen);
lv_obj_add_style(sGuiVar.poText, &sStyleDefault, LV_PART_MAIN);
lv_obj_add_style(sGuiVar.poText, &sStyleInfoWin, LV_PART_MAIN); // InfoWindow (Text & Graph) specifics
{ // Create Graph "wrapper" for chart, scales & series
sGuiVar.poGraph = lv_obj_create(sGuiVar.poScreen);
lv_obj_add_style(sGuiVar.poGraph, &sStyleDefault, LV_PART_MAIN);
lv_obj_add_style(sGuiVar.poGraph, &sStyleInfoWin, LV_PART_MAIN); // InfoWindow (Text & Graph) specifics
{ // Create Chart object
sGuiVar.poChart = lv_chart_create(sGuiVar.poGraph);
lv_obj_add_style(sGuiVar.poChart, &sStyleDefault, LV_PART_MAIN);
lv_obj_add_style(sGuiVar.poChart, &sStyleChart, LV_PART_MAIN); // Chart specific
lv_obj_align(sGuiVar.poChart, LV_ALIGN_TOP_LEFT, lvlglCHART_MARGIN_X/2, lvlglCHART_MARGIN_Y/2);
lv_chart_set_type(sGuiVar.poChart, LV_CHART_TYPE_LINE);
lv_chart_set_point_count(sGuiVar.poChart, sGraphCfg.Points);
lv_chart_set_update_mode(sGuiVar.poChart, LV_CHART_UPDATE_MODE_SHIFT);
lv_chart_set_div_line_count(sGuiVar.poChart, sGraphCfg.DivLineX, sGraphCfg.DivLineY);
{ // create scale object(s)
for (int axis = axisVL; axis < axisNUM; ++axis) {
if (sGraphCfg.psScC[axis]) {
sGuiVar.psScV[axis] = psGuiCreateScale(sGuiVar.poChart, sGraphCfg.psScC[axis], axis);
// lv_obj_align_to(sGuiVar.psScV[axis]->poScale,sGuiVar.poGraph,LV_ALIGN_DEFAULT, 0, 0);
{ // Create button object(s)
sGuiVar.poButtons = lv_obj_create(sGuiVar.poScreen);
lv_obj_add_style(sGuiVar.poButtons, &sStyleDefault, LV_PART_MAIN);
lv_obj_add_style(sGuiVar.poButtons, &sStyleBtnsWin, LV_PART_MAIN);
lv_obj_set_pos(sGuiVar.poButtons, lvglBUTTON_TLX, lvglBUTTON_TLY);
vGuiButtonsCreate(sGuiVar.poButtons, (btn_cfg_t *) &sBtnCfg, vGuiButtonsCB);
lv_obj_add_event_cb(sGuiVar.poScreen, vGuiButtonsCB, LV_EVENT_PRESSED, NULL);
vGuiObjectSwap(sGuiVar.poGraph, sGuiVar.poText); // make text window (page 0->3) active
sGuiVar.msTouchTO = lvglMS_TOUCH_TO;
sGuiVar.psTmr = lv_timer_create(vGuiTimerCB, lvglMS_TIMER, NULL);
lvgl_port_unlock();
Just to clarify
In the image above the VL/red, VR/blue and HB/green scales are at exactly the correct position.
What I am trying to do is shrink the area of the chart, as indicated by the white divider lines, to neatly occupy the area between the 3 scales.
This will then also move the starting position of the initial points slightly to the right to be immediately to the right of the VL/red scale, and the last plotting point should be immediately to the left of the VR/blue scale.
