Porting to mikroC
Did anyone ported LittlevGL to mikroC from mikroElektronika for PIC32? I am reading manual but still I am lost :slight_smile :slight_smile:
PIC32MX custom made board with ILI9341 TFT and mikroC for PIC32 compiler
To use library without OS, just bare metal…
Reading manual, and still lost…
What are you lost on? This should be fairly straight forward. Can you get LVGL to compile without display hardware? That is step 1, step 2 is including the Output/Input modules.
Well, I have my old code which initialize MCU and TFT. Driver for ILI9341 which works OK and using PMP module of PIC32MX. Now I am reading manual, and I am completely lost, whats next step, I can compile, and next step is to register/connect driver and library. I am reading manual, and still not sure how to do it… I know its simple, since I am stuck on this since yesterday, I might simply just “can’t see forest for the trees”…
Thanks for fast reply,
It’s better if you ask a specific question that has a specific answer. Questions like “how to make the whole library work” are very generic.
