skpang
September 17, 2020, 9:11pm
#1
I’m try to port LVGL to STM32H743 but having problem with display flush. The image on the screen is garbled.
static void ex_disp_flush(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p)
int32_t x, y;
BSP_LCD_DrawPixel(x, y, (uint32_t *)color_p);
color_p++;
I know the display is working as I can draw solid bars like this:
for(y=50;y<200;y++) {
for(x = 0; x <1023; x++) {
BSP_LCD_DrawPixel(x, y, 0x001F);
Any ideas of how to fix this ? I’m using version 7.5.0 and RGB565 mode
did you try the code on simulator?
skpang
September 17, 2020, 9:59pm
#3
No, I couldn’t get the simulator to install on an iMac.
I’ve got LVGL working on the ESP32, Teensy 4 and STM32F discovery board.
I think there is a display buffer configuration issue.
I think you want BSP_LCD_DrawPixel(x, y, color_p->full);
skpang
September 18, 2020, 1:40pm
#5
After I changed it to:
I get a white/grey screen but the ex_disp_flush doesn’t get called to draw the label/buttons.
I know the lv_tick_inc(1); is called as it stops if I put a breakpoint there.
The log shows:
Trace: indev read task finished .(lv_indev.c #129 _lv_indev_read_task())
Trace: lv_task_handler ready .(lv_task.c #192 lv_task_handler())
Trace: lv_task_handler started .(lv_task.c #74 lv_task_handler())
Trace: indev read task started .(lv_indev.c #77 _lv_indev_read_task())
Trace: idnev read started .(lv_hal_indev.c #153 _lv_indev_read())
Trace: idnev read finished .(lv_hal_indev.c #155 _lv_indev_read())
but no screen update.
@skpang
Just Use :
uint16_t width = (area->x2 - area->x1 +1);
uint16_t height = (area->y2 - area->y1+1);
BSP_LCD_DrawRGB16Image( area->x1, area->y1, width , height, (uint16_t *)color_p);
Hello do you think I could see your code base possibly as I’m currently attempting to get LVGL working on a STMH7 as well but keep having it hang.
skpang
January 27, 2021, 9:58am
#9
Its not in state I can release at the moment.
In your code try and turn off cache for now.
Comment out clearing of the cache is well. I had to do that as I could not get the cache to work.
